  • Guests: 48
Will T (16)
william L (29)
Tipiment (62)
12/17 Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
is there any mods that can help a sstc in wirelass energy tranfer
Wed Sept 15 2010, 08:07PM Print
803 Registered Member #2807 Joined: Fri Apr 16 2010, 08:10PM
I'm using steve's mini sstc and the reciver is the same secondary and primary connected to a bridge rectifier. I'm wanting 50% over 1 meter
Thu Sept 16 2010, 12:36PM
Just make sure that the bridge rectifier is made of FAST diodes,
UF4007 or similar (Trr << 1us)
radiotech
Thu Sept 16 2010, 06:22PM
The surest way to measure if energy transferred is to measure the heat. That isn't going to be easy unless you can use a thermopile of some description. Find out how Hertz did that. For your experiment, you could find the smallest lightbulb, ie a #49 (2 volts- 0.06 amps)
and connect it across the primary coil of the recieving coil and then try moving close enough to the the sender get it to light.
Here is the innards of a very broad range probe used to measure EM power using heat.
1284661322 2463 FT96626 Scan0024
