  • Guests: 65
CT2 (37)
Josh Johnson (46)
01/21 Banana Man (41)
01/21 TheAnomaly (13)
01/23 GimpyJoe (36)
Show me your primary tap
Wed Sept 15 2010, 04:16PM Print
Hi All
I am currently thinking of a way to make my primary tap for my DRSSTC. I do not want to go with the fuseholder solution.
What I have thought of so far according to the attached picture is a piece of copper bar bend in a U shape with a screw on that presses a "plate" against the the primary, this plate will be "covered" in screen from a cable for better contact, as I suggested Finn on his thumper.
But for inspiration and if there is better solutions, please show me how you do it, this is now a good place to brag and show off your genius solutions :D
1284567413 1403 FT0 Primary Tap
Marko
Wed Sept 15 2010, 04:58PM
Hi mads,
Since fuse clips frustrated me as well, I thought about possible ways of devising a screw-down mechanism like yours. I couldn't figure out how to make something that can easily get into and between the turns without requiring to disassemble it - in your picture, how do you intend to detach the U bar from your plate and cable when you want to tap to another turn? you can only slide it a limited distance between primary supports.
I also didn't like my primary clip twist up and down when attached to primary, Hence I ended up using four fuse clips, only two of which are actual contacts, in my Big Bad the SSTC. Fuse clips actually work surprisingly well (if they are brass, not steel!) and I always polish the surface when re-tapping.
1283210442 89 FT0 Primary Large
Marko
Wed Sept 15 2010, 05:35PM
Oops.. you got me there, didn't think that one through, its impossible to get off again :D
Here is a revision, but its beginning to be quite some parts...
There is the U shaped copper, with a hole for connecting the primary lead with a cable shoe.
The brown pin through the U shape is threaded in the middle for the grey screw to go into, it presses a small copper piece against the tubing and locks with the U shaped pressing the cable shield in the back "yellow" against the tubing.
It can all be disasembled and moved, but its some work and the primary wire gets too far out from the primary to my liking... Ill better sit here trying to think of a better clamp...
Maybe a brass clamp, like a giant fuse holder, but machined with a mill, only just to fit my 10 mm tubing could be good... but no mill at my disposal...
I am sorry for the crude picture, but my girlfriends tiny notebook only got a tiny touchpad :D
1284572151 1403 FT96620 New Tap
radiotech
Wed Sept 15 2010, 07:02PM
From the Industrial Electricty side - We call these splitbolt connectors and then come in many sizes.
1284577337 2463 FT96620 Scan0035
1284577337 2463 FT96620 Splitbolt
Wed Sept 15 2010, 08:28PM
radiotech wrote ...
Yea, my dad has some, i used them for a primary once. I used it with the flat part facing down, and i cut the splitbolt to size so it did not touch the winding above it. I brazed the thick litz to the flat part.
It worked well, but i stupidly crushed the tubing, i got it too tight. Not to mention, on the copper piece that is connected to the nut, there is an edge in the middle, so it crushed the middle of the pipe inward. If they have the same nuts with that piece of copper rounded, that would be great.
Marko
Wed Sept 15 2010, 09:42PM
How about simply drilling holes in the thick copper tube and tapping to them? It should not be too difficult to drill even a M5 or M6 hole every 10cm or so, and then re-run with a tap in the drill? You only need to do it on 2 or 3 turns, and it seems like less work than building a delicate tap. Or just use a fuse clip for start, and then drill a few holes later.
Marko
Wed Sept 15 2010, 10:40PM
radiotech wrote ...
Good picture, as usual!
The lower-right illustration shows cable clips installed correctly, where many people don't realize that it matters.
Whether you are terminating a copper conductor or a steel wire rope, the U-bolt should touch the dead section of the line, while the live section rests on the forged or cast saddle part. When clips are installed upside down, the connection is less strong, because the U-bolt indents and concentrates stress on the load-bearing line.
"Never saddle a dead horse."
Thu Sept 16 2010, 10:00AM
How about something like this? Link2
Dr. Drone
Thu Sept 16 2010, 08:48PM
shades
Sun Sept 19 2010, 06:08AM
Dr. Spark wrote ...
Here is a new way am connecting the primary on the DRSSTC Bi-polar, just wrap a small strip of copper around primary and bolt down. Takes less than minute to move.
Spark On,
1284669942 290 FT96620 Primary 1
This is excatly what I was looking for, thanks for pointing me in that direction, is always hard to keep it simple :)
