  • Guests: 54
6 Pulse Rectifier
Micha0_0
Sun Sept 12 2010, 11:29PM Print
Micha0_0 Registered Member #2990 Joined: Mon Jul 12 2010, 11:22AM
Hey guys !
i got a 3 phase transformer which gives me about 10 kv @ 2 amp
i want to convert the 3phase ac voltage to DC voltage
i want to make it with a 6 pulse rectifier
so i thought 6 strings of 25x 1N5408 doides in series
so it could handle 25 kv at 3 amp
would be 150 diodes
could i use 6 strings of [3strings 25x 1N4007 each]--> would be 18 strings with 25x 1N4007 .
it could also handle 25KV at 3 amp
would be 450 diodes.
because the 1N4007 would be a lot cheaper than the 1N5408
and i would have the same effect.
or is it better if i use the 1N5408?
LG Micha
and
radiotech
Mon Sept 13 2010, 01:31AM
What power source is the transformer connected to? Can you post a picture of the nameplate, and possibly the transformer?
This may help you desisn your rectifier: it shows 3 types of 3 phase windings connected to 6 rectifiers..
1284341476 2463 FT96443 Scan0028
Micha0_0
Mon Sept 13 2010, 11:07AM
hey...
thanks for your post
do you mean what feed my transformer?
sry it's an old transfrmer ...there's no nameplate on it
i searched on google ...and i found something...
Fzmmmfzr
Mon Sept 13 2010, 11:12AM
The 1N400x is only rated at 1 amp. You definitely want the 1N5408.
The difference in cost will vanish once you take into account the cost of your labour, rebuilding the diode strings after you blew them a few times. No doubt you'll be messing around with the transformer, pulling giant arcs from it and generally overloading it beyond its rating, so you want the strongest diodes you can easily get.
Diodes aren't supposed to be connected in parallel: they're not guaranteed to share the current equally.
Yes, that schematic above is correct for a 6 pulse rectifier.
Micha0_0
Mon Sept 13 2010, 11:24AM
okey thanks...
then i'll buy the 1N5408
...another question...
will the diods get hot ?
need they to be cooled ?
i saw a pic from someone who had the same..and he put the diod strings in a plastic tube .
is that good or better when i put them under oil ?!
LG micha
radiotech
Mon Sept 13 2010, 05:12PM
Are You going to be connecting your transformer to a three phase power source?
How did you find the 2 amp 20kV rating. Thats 69 kVa. What is the other winding voltage?
Micha0_0
Mon Sept 13 2010, 07:47PM
yes it's a 3 phase power line
400V input
output is about 10kv not 20kv
