  • Guests: 62
Class-E Tesla Coil working with direct mains power
cjk2
Sat Sept 11 2010, 01:39AM Print
I set this up in about a day. I based my circuit on waverider's work. My coil resonates at about 4mhz and will produce about 1.5" of corona with 170vdc input. I am currently running from an isolation transformer so I can scope my gate and drain. I intend to make a simple wooden base for this coil and set it on my desk as a demo unit.
http://www.youtube.com/watch?v=HQfR-wsDoBI
Lg
Lg
Lg
Matt Edwards
Sat Sept 11 2010, 05:02AM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Nice! You should post some specs and schematics when you get a chance.
GeordieBoy
Sat Sept 11 2010, 10:35AM
Cool! What do you use as the source for the oscillation? 4MHz crystal, VCO, external signal generator, or self-oscillating feedback from the TC resonator?
-Richie,
PS. You might need a heatsink on the bridge rectifier if you are running a few hundred watts of power from a 110V mains line!
Marko
Sat Sept 11 2010, 01:36PM
Hi,
Richie - if you looked at the video, it looks like he's using a sigle turn feedback winding under the coil - still resulting in 60V p-p at the gate. :O
cjk2 - how much power does the coil draw to produce that kind of spark? It's proably the largest spark I've seen so far from single-mosfet-and-feedback-winding coils. Also if you blew no mosfets while achieving this, I'm very impressed.
Still what I'm most surprised with is how are you getting away with primary made of such tiny wire. I would expect it to start smoking after 30s on that video.
Marko
Muttyfutty!
Sat Sept 11 2010, 02:55PM
Muttyfutty! Registered Member #2915 Joined: Fri Jun 11 2010, 10:41AM
Very nice, Hot arcs!
Good job, I hope to try this when I have time.
Just pointing out, The schematic is in the video description, YAY!
cjk2
Sat Sept 11 2010, 03:26PM
-Richie,
I am using a flattened single turn feedback winding. I actually have not had any problems with the rectifier overheating. I estimate it is dissipating about 3W and it seems to be ok for short runs. I do have the space to add an aluminum fin to it if needed.
I destroyed the gate oxide on one FET during testing due to using a full turn for my feedback winding and causing a few hundred volts to appear on its gate. It looks like I am drawing about 2A at 120V RMS which implies 240W. I have no idea if this is at all accurate as power factor likely has an effect here. My primary does get hot and will be replaced with 18AWG wire when I get around to it. Still, with an average of 2A through it, the 23AWG only gets hot during extended runs.
1284218794 51 FT96336 Off Line Class E Sch
Crunchy Frog
Sat Sept 11 2010, 07:29PM
Crunchy Frog Registered Member #2422 Joined: Tue Oct 06 2009, 02:41AM
Very impressive for such a simple design! How does it self-start?
william L
Sat Sept 11 2010, 08:24PM
william L Registered Member #3093 Joined: Mon Aug 09 2010, 11:40PM
Crunchy Frog wrote ...
Looks to me like a pulse goes through the primary and resonant cap, which triggers the gate, and it keeps on cycling.
also, what is the lowest voltage that you can achieve a breakout?
Mon Sept 13 2010, 11:19AM
Looks like it starts by biasing the MOSFET on a little so it works as a linear amplifier. The circuit will start in Class A and ring its way up through B, C, D and E. smile
This is a nice little circuit, it's too bad we can't do it here in 230V land. :-<
Luca
Mon Sept 13 2010, 12:26PM
Luca Registered Member #2481 Joined: Mon Nov 23 2009, 03:07PM
Steve McConner wrote ...
Why not? mistrust
Luca
