  • Guests: 52
Arjan EMM (52)
01/01 Bosko (56)
01/01 hen918 (30)
01/01 Yuri_Ivanov (35)
Van Der Graaf Generator
Pyr0maniac
Thu Sept 09 2010, 08:10PM Print
Pyr0maniac Registered Member #3165 Joined: Sat Sept 04 2010, 03:24PM
Hi guys!
I've now pretty much given up on building a tesla coil, since it's so hard to get hold of an NST in this country.
I've decided to have a go at a van der graaf generator though, since this doesn't use an external power source as such.
At the moment i have a cotton reel covered in PTFE thread seal tape ,(teflon), for the top roller, and a pyrex test tube ,(glass, obviously), cut short and filled with a shaft bound in tape. The belt will be a strip of material from a pair of tights (i believe you yanks call them pantyhose). Not sure what i will use to drive it yet. I have a motor from an RC car, but it's a bit fast when run straight from the shaft. I might try to get something more slow and steady like a wiper motor. I haven't ruled out hand power either if i can find an appropriate gearing system. This will all be housed in PVC pipe with a polystyrene ball or similar coated in adhesive zinc on top. Does this sound like it could work?
radiotech
Fri Sept 10 2010, 06:36AM
The zink coating must contact the top belt collector and some machine house the top pulley inside the top dome to do this. I wonder if the zink adhesive is smooth and does not present a series of jagged points from which corona will drain the charge before the dome charges up. How are you going to fashion the (nylon) pantihose into a smooth belt? Wont the knot rattle?
Is your belt speed going to be about 3M/second with that motor?
Tesla Coils can be powered from an auto ignition coil too.
Fri Sept 10 2010, 01:17PM
You could also try a Wimhurst machine.
Pyr0maniac
Fri Sept 10 2010, 04:11PM
radiotech wrote ...
I plan to wire the zinc coating to the top comb. Hopefully i can find a way to accommodate the top comb in the ball (or whatever else i find). Otherwise it will have to be just below, which will reduce the efficiency a bit.
The zinc should be fairly smooth once i rub it down. If i can find a decent metal object i will use that instead, or aluminium foil.
I will try to sew the material into a decent belt so there is almost no visible join.
Is 3m/s what i should be aiming for? This isn't going to be huge, so that sounds a bit fast. For that i would need about 2200rpm on the motor, which probably isn't possible. I have no idea what the rating on it is.
Adam Munich
Fri Sept 10 2010, 07:29PM
I would go with a whimhurst machine. They're easy to make, and you don't need a huge perfectly smooth hollow steel ball. (~$200 for a 20" one)
And what country do you live in? It's possible to make a tesla coil with a few microwave oven transformers in series under oil. You can limit the current with a 500 watt halogen bulb.
radiotech
Fri Sept 10 2010, 08:03PM
Small fan motors might be used. What is the diameter of the belt drive pulley?
Here's another electric machine you could try.
1284149034 2463 FT96260 Scan0020
Antonio
Fri Sept 10 2010, 11:17PM
"Van de Graaff", "Wimshurst". Probably the two names most misspelled in the history of electricity...
Electrostatic machines, almost all of them:
Mino
Thu Sept 23 2010, 12:27PM
Mino Registered Member #2572 Joined: Sat Dec 26 2009, 05:03PM
Hello Pyr0maniac,
i´ve bulid a VDG a few months ago.
Here is a link:
Sorry...it´s the german forum about HV...I hope the pics can also help....
Mino
paris
Mon Oct 04 2010, 02:13AM
paris Registered Member #3042 Joined: Wed Jul 28 2010, 12:36AM
hi,
theres some interesting stuff on e.s machines on the net , saw one set up using old VINYL records for the rotors ,those things were always static ,there were heaps of products to combat static ,so thats a good use for old LPs.
Martin van Marum in 1785 made a generator that put out 750kv , 24 inch arcs using glass rotors. WICKED
Pyr0maniac
Sun Oct 10 2010, 04:54PM
The glass roller shattered when i tried to cut it to size :(
I now have a teflon (cotton reel with PTFE tape) roller, and a card/tape roller with parcel tape on the surface (which unusually is very positive, most tapes are more negative). The ball is two 5.5" bowls taped together.
The belt is some rubber (probably latex) for physiotherapy. Haven't started on the stand yet, and at the moment i'm using a cordless drill as a temporary motor, but i was getting sparks over 0.5" which wasn't bad considering i haven't degreased the belt or kept anything moisture free at all. I need to work on adjusting my combs, i'm guessing that is the limiting factor at the moment. Pics soon.
I also just have a metal bar rather than a smaller ball for discharges which may be limiting the arc length a bit.
