  • Guests: 54
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
IXGN60N60C2D1
Gregory
Tue Sept 07 2010, 01:07AM Print
i will use this igbts in my new drsstc, the secondary is 80cm of wire 26 awg (i think that is very big and wont work.. what you think?)
i am think in put a 1:2:2 gdt to drive the igbts, but i don't now if 30v in the gate will blow? it will reduce the life? can i put 33v zener? or 20v?
what is the maximum frequency that can i run this igbts?
Hei
Tue Sept 07 2010, 01:18AM
Hei Registered Member #2808 Joined: Sat Apr 17 2010, 03:25AM
Your coils look really big smile
I've been using 12v on the gate ic which gives 24v on the igbts, and they looks fine.it seems that the 40n60 minibrick can push to around 500kHz, I think these igbt can do the same aswell.
Gregory
Tue Sept 07 2010, 01:39AM
thank you, but i am thinking that i will remake the secondary with 30awg and a height of 50cm
can i put 500A of peak in this igbt?
Gregory
Tue Sept 07 2010, 02:36AM
sorry about the double post i have already edited the other
Goodchild
Wed Sept 08 2010, 04:20PM
Yes you can push 500A though those IGBTs but be warned that's about the upper limit for those IGBTs also If you are going to push 500A I suggest keeping the Fo below 100KHz
Gregory
Wed Sept 08 2010, 05:17PM
Yes, I think of 90kHz and OCD for 500 or 600A with a duty no higher than 8% with maximum TON of 160us. will be security?
and more than 20v in gate will reduce the life of the igbts? a lot?
Goodchild
Wed Sept 08 2010, 05:27PM
Run the IGBTs at no more than 30V I run all my IGBT's at 24V drive and have had no problems with it.
You shouldn't need to run any more than 100uS.
Also don't run those IGBT's at 600A that will kill them no higher than 500A.
Gregory
Wed Sept 08 2010, 05:52PM
but, steve runed more than 800A in this type of igbt??
Goodchild
Thu Sept 09 2010, 02:21PM
Umm.. no he doesn't you are thinking of 40N60s not 60N60s I know for a fact that if put more than 550A though those you will kill them.
Gregory
Thu Sept 09 2010, 04:36PM
ohh, okk, i was thinking that the 60n60 is better than the 40n60
