  • Guests: 57
Will this transformer do?
Pyr0maniac
Sat Sept 04 2010, 03:29PM Print
Pyr0maniac Registered Member #3165 Joined: Sat Sept 04 2010, 03:24PM
Hi, i'm new to the forum wink
I'm looking to build a smallish Tesla coil, would this one be good enough. I think it's 7.5kV, so i'm guessing it's ok?
Thanks!
Adam Munich
Sat Sept 04 2010, 08:52PM
It would, but I'd go with an NST instead. OBITS require external current limiting, otherwise they burn themselves out.
Pyr0maniac
Sat Sept 04 2010, 09:49PM
Anyone know anywhere where i can pick up a NST then? The cheapest i can find one is about £60 after postage in the UK.
radiotech
Sat Sept 04 2010, 10:07PM
Its 15 kV.
Herr Zapp
Sun Sept 05 2010, 05:27AM
Grenadier wrote -
"OBITS require external current limiting, otherwise they burn themselves out."
This is NOT true. Oil Burner Ignition Transformers (OBITs)are intended to be powered directly by AC line voltage; no form of current limiting is required.
15 seconds of Googling would have yielded more information about the Danfoss OBITs: Link2
Because these are solid-state, high frequency modules, they probably won't work for driving a conventional AC spark-gap Tesla coil. However, because of their high frequency AC output (20KHz) they might be suitable for use in a Cockroft-Walton voltage multiplier.
Herr Zapp
Pyr0maniac
Sun Sept 05 2010, 09:37AM
Thanks. There's one going very cheap on ebay at the moment so i might give it a go. I don't have the money for an NST right now and since this is my first coil i'm not expecting much.
Sun Sept 05 2010, 10:32AM
If you go to neon sign shops and ask nicely they might give you one of their olds NSTs
Pyr0maniac
Sun Sept 05 2010, 12:58PM
didn't win the OBIT, what are these like?
Sun Sept 05 2010, 03:08PM
its a switchmode NST, not usable for a SGTC unless you rectify it (but you still cant benefit from the resonant cap charging like with a line frequency NST).
Pyr0maniac
Sun Sept 05 2010, 06:13PM
yeh, think i'm just gonna wait until a decent NST shows up on ebay.
