  • Guests: 50
How does a Bonetti machine work and how is it different from the Wimshurst machine?
lkjh
Fri Sept 03 2010, 09:32PM Print
lkjh Registered Member #3162 Joined: Thu Sept 02 2010, 10:28PM
How does a Bonetti machine work and how is it different from the Wimshurst machine? I understand the basic operation of the Wimshurst machine, and that the Bonetti machine lacks sectors and needs initial charging but not much more than that. I found this page: Link2 which is helpful but it doesn't seem to explain this. I wanted to make a Wimshurst machine like in makezine 17, but then I found out about the Bonetti machine and it seems more efficient and I don't even need sectors.
Antonio
Sat Sept 04 2010, 12:04AM
It works exactly as the Wimshurst machine, but transports charge directly over the insulating disk surfaces, using sets of wide brushes in the neutralizers (better) or combs to move it. It is more powerful, but quite inconvenient because it needs an initial charge on the disks to start. It may not work if the humidity level in the air is high, while a Wimshurst machine still works. You may need another machine to start it. (I wrote the page in the link.)
lkjh
Sat Sept 04 2010, 01:22AM
So I could build a Wimshurst machine first then use it to start the Bonetti machine (if I build one)?
Dr. Slack
Sat Sept 04 2010, 02:10PM
The induction charging geometry each uses is exactly the same. Shifting the charge about between places on the plates is different.
In a Whimhurst, it has metal sectors and brushes, so charge can flow at any voltage. Just the slightist stray charge is enough to get it started, so it self-starts.
A Bonetti OTOH has an insulating plate surface, so charge has to be sprayed onto/off of the plates, which requires a minimum voltage of, ooh, guesses here, somewhere between 1 and 10kV, enough to create a corona wind anyway. So it needs a kick start.
Antonio
Sat Sept 04 2010, 04:27PM
You both are right. A Wimshurst machine can start a Bonetti machine easily. Place one of the terminals of the Wimshurst opposite to one of the neutralizers of the Bonetti, turn the Wimshurst until it is fully charged, and then turn the Bonetti. Move the Wimshurst away after the machine starts. It will keep the charge for long time in a dry place. It's also possible to start the machine, in a dry place, by placing a large PVC tube electrized by friction behind one of the neutralizers and then turning the machine.
Adam Munich
Sat Sept 04 2010, 08:49PM
I wonder how big would the whimhurst machine need to be. I'd really like to see a little 6" one spun at 3000 RPM!
Antonio
Sun Sept 05 2010, 12:35AM
To excite a Bonetti? Not critical. Even one of those made with CD disks would work. A Bonetti machine with combs at the neutralizers is convenient to run at high speeds, since nothing touches the disks. It's perfectly possible to build one with two motors powering directly the disks.
Adam Munich
Sun Sept 05 2010, 01:22AM
I want to build a whimhurst now...
