  • Guests: 61
Anyone know of a device...
Nicko
Fri Sept 03 2010, 08:36PM Print
...that has an FM tuner in it and re-broadcasts on a given fixed AM frequency (MW or LW)? Cheap & cheerful, hopefully. Maybe even with MP3 & line-in support too!
The reason? In my infinite stupidity, I have just spent a couple of days fully restoring/rebuilding a nice little 4 valve mains/battery portable radio. Very pretty little thing. Couldn't resist it. A present for SWMBO. Works a treat now (the radio, that is).
One (slight) problem is that there is not much around on AM any more, unless you like faint whistling German and Russian stations late at night... so I want to get an FM tuner to rebroadcast very (very) locally (a few meters would be good) on AM at say 500M or so, so I can use my (wife's!) nice restored radio.
For those who care about such things, its a Vidor "Lady Anne" from 1955.
Surely someone, somewhere, must produce something for this!
Cheers
Avalanche
Fri Sept 03 2010, 09:02PM
I don't know of any commercial product, but it's very common for radio restorers to build their own 'micropower' transmitters for this exact purpose, for example see Link2
I'm actually building one myself, using a much simpler 'off the shelf' approach - a 4Mhz crystal oscillator divided down to 1Mhz (exact 50% duty cycle square wave) driving a resonant LC circuit through a small amplifier stage. Amplitude modulation is done using high level modulation (modulating the DC rail of the class c stage). I'm doing this so I can listen to whatever I want on my recently restored GEC radio, and a couple of others I have.
Not quite what you're after, but I can post the schematic if interested once I have ironed out the bugs?
Nicko
Fri Sept 03 2010, 09:26PM
Ah! That's you is it! - I'd seen that. Its my "Lady Anne" in the "Vintage Radio (domestic)" forum of the same site that I want to drive... I rather like restoring old radios now... got the bug...
I was looking at the "iTx - Tube AM Broadcast Transmitter Kit" from the Vintage Component Company as well as their "Spitfire - AM Medium Wave & Top Band (160M) Transmitter". Both look good - the iTx because its tube-based, and the Spitfire because its comprehensive and fully boxed already. Another is the AMT3000 from SSTRAN Link2
I'd certainly be interested in your project as it progresses...
Cheers
Adam Munich
Fri Sept 03 2010, 10:28PM
You can use a 1MHz crystal oscillator to broadcast on AM. (at 1000kHz of course) Link2
Link to buy oscillator. Link2
Sun Sept 05 2010, 12:49AM
an "old school" trick is to use a homemade lambda diode using J310 and BC212 transistors and a tuning diode made of red LEDs in reverse bias.
-A
"Bother" said Pooh, as Nature rejected his paper on 281k superconductivity...
Mark-H
Thu Sept 09 2010, 10:52AM
Mark-H Registered Member #607 Joined: Tue Mar 27 2007, 10:39AM
Nick.
The 1000KHz osc and "recovered internals" of a cheap pocket FM radio is the way I've done it to over 30! Vidor Lady Margaret and Lady Catherine radios over the last 10 years.
As of late, all the pocket stuff has come from Freecycle.
A very cheap and compact mod that I build into the B battery (These two models are battery portables from Vidor in Erith.)
The B should be 90V but these will work down to 45V or even 27V so I can reduce the PP3s in the box.
I power this from the filament A battery.
Cheers.
Mark.
radiotech
Thu Sept 09 2010, 03:36PM
Never used led's- old top hat rectifiers would shift enough to sweep the AM band. I do have a Heath 2240 4-point LR bridge
that allows using externnal DC bias on capacitors to test some some new LEDs on. Wonder if they would work as photo-capacitors like the vidicon screen coating does?
Thu Sept 09 2010, 08:05PM
interesting..
someone on the amateur radio forums suggested that often "old" germanium diodes can somehow be persuaded to oscillate by careful cooking (forward bias under substantial current until it starts to drop, then allow it to cool), which ruins the diode for conventional use but gives it a weak negative resistance zone due to electromigration or something ?
supposedly some LEDs behave the same, although most of the time the ball bond goes OMGWTFLEDBBQ and opens.
can someone investigate this "effect" please?
regards, -A
"Bother" said Pooh, as his cortical node malfunctioned...
Adam Munich
Thu Sept 09 2010, 08:47PM
"supposedly some LEDs behave the same, although most of the time the ball bond goes OMGWTFLEDBBQ and opens."
You could try and attempt it with a cree led. They solder the chip.
radiotech
Fri Sept 10 2010, 02:05AM
Back in dim dark past there was a transistor with an alpha >1
called a hook transistor. They seem to have stumbled on them by screwing up a point contact transistor during manufacture.Maybe cooking the diodes created extra layers like a diac. Just think of the fun of altering leds with a laser or microwaves.
Years ago there was a great plentitude of Osram type R valves to play with and their characteristics could be altered by carefully melting depressions in the envelope with a bunsen burner.
If anyone knows why these appeared by the thousands in Montreal 50 years ago please tell.
1284084312 2463 FT95797 Osram
