  • Guests: 36
12/29 Cprossu (40)
12/29 Kokamo (46)
12/29 GalliumMan (60)
Testing salt water cap with spark gap
HM_Murdock
Fri Sept 03 2010, 02:26PM Print
HM_Murdock Registered Member #3075 Joined: Fri Aug 06 2010, 02:44PM
I have built a saltwater cap, and I want to make certain I am testing it correctly...
Using a 9kV/30mA NST, and I plan on wiring it as such with 10AWG stranded (600V) wire and two bolts for a temp spark gap.
Two questions:
1- is this ok to test with (have I got this right?)?
2- where should I set the initial gap?
Cap
radiotech
Fri Sept 03 2010, 03:28PM
What are you testing the electrolytic gap for?
HM_Murdock
Fri Sept 03 2010, 03:35PM
Not 100% sure I have the right terminology here...
I basically want to test out my spark gap to make sure my cap is working and get an idea of the max width I can go on the gap to still get a spark. I have read this is how you are supposed to test the gap before hooking it to your primary on the TC?
radiotech
Fri Sept 03 2010, 06:43PM
Spark gaps can be used to check voltage and somtimes are calibrated with a voltage scale. This oil gap is adjusted to see if the oil can prevent arc-over of a particular voiltage, to see if the oil is good.
1283539436 2463 FT95772 Oil
HM_Murdock
Fri Sept 03 2010, 07:25PM
I am building a SGTC cap bank.
I want to be able to set up the safety gap (which I just realized I left out of my drawing) and the main spark gap.
I have read conflicting information on how to go about this, so I am trying to find out the 'right' way to do it.
Best I can tell, I should wire up JUST the NST and safty gap, and set the safety gap wide enough to where it just quits arcing.
then, I hook up the circuit as shown below, and set the spark gap so that it is just close enough to keep a constant arc, at which point it should be quite loud (and the safety gap is not firing)
Am I on the right track here, or what?
Cap2
Muttyfutty!
Sat Sept 04 2010, 01:28AM
Muttyfutty! Registered Member #2915 Joined: Fri Jun 11 2010, 10:41AM
First disconnect the cap, you don't need it to set the safety.
Next, increase the safety gap size in small increments until it no longer fires and
increase it very slightly more. so when the main gap fires the safety gap doesn't.
The idea it that if the main gap fails, the safety gap fires before the voltage spike fries a Cap/NST etc...
This is a very good site to get you started, I recommend reading it thoroughly :)
Good luck, and don't forget to exercise caution when working with HV (or any) Capacitors...
HM_Murdock
Sat Sept 04 2010, 02:22AM
Thanks Muttyfutty!
I have read (and re-read, and re-read) that site (and used the Teslamap program), as well as all the other ones I can find. In fact, that site is where I got my spark gap settings procedure from. I just wanted to make sure I had the wiring right, and was going about it the right way before I actually did it.
Got my new cap made tonight (used wine bottles this time, and all saltwater - no foil). Must have done something right, as it is LOUD!! amazed
Got my safety gap all set, then connected the cap and spark gap. I could possibly go a tad wider on the spark gap, but I'm not looking to push it. As-is, the safety is just a hair away from firing with nothing but the NST connected with it, and it doesn't fire at all with the cap bank hooked up. Getting a solid 10.41nF with this cap.
Here's some pics, and a video...and man, the video doesn't do the volume justice...sounds like firecrackers going off like a machine gun! Me like!
1283566909 3075 FT95772 Dscf5907
1283566909 3075 FT95772 Dscf5908
1283566909 3075 FT95772 Dscf5909
1283566909 3075 FT95772 Dscf5913
1283566909 3075 FT95772 Dscf5914
1283566909 3075 FT95772 Dscf5918
]spark_gap_test.wmv[/file]
Xplorer
Sat Sept 04 2010, 04:01AM
Xplorer Registered Member #2416 Joined: Sun Oct 04 2009, 04:23AM
Nice work. 10nf is on par with what you need. I think 13nF is an LTR static gap for a 9/30. Once you want to upgrade to a real capacitor, 11 CDEs in series will do it.
If you thought the SG was noisy, just wait till you get your first streamers. Even small ones (~6in) are defining.
-Tony
Muttyfutty!
Sat Sept 04 2010, 04:45AM
WOW, looks good!
When I first connected my 8nF cap to my NST I jumped about 2 feet in the air in shock, Never before had I heard such a loud bang!
Now I know what to expect when I (finally) finish my SGTC...
