  • Guests: 15
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
basicly math based question, (ns)
Duality
Tue Aug 31 2010, 09:59PM Print
Duality Registered Member #1951 Joined: Sun Feb 01 2009, 01:59PM
hello everyone i don't know if i placed it in the right section, but i have a problem, that is math.
frequency in Hz is how Manny times something happens in a second, lets take sound, Hz is two times a second, frequency is 2 Hz.
now i have something that can't happen past 220 ns (nanoseconds) how can i visualize this in terms of frequency can i say not beyond 220MHz? or am i just thinking plane wrong here? cause i have the feeling i am just thinking wrong here.
lets take a switch that can switch, (lol) but can't make smaller passes then 220 ns means it can switch at 220 MHz?
if im not clear please tell me :)
AleSeg
Tue Aug 31 2010, 10:30PM
AleSeg Registered Member #2727 Joined: Tue Mar 09 2010, 02:39PM
I don't know if i understand all, but when you speak about frequency you are considering periodical phenomena, and numerically f = 1/T, where T is the period of repetition of the signal in seconds, and f is the freq in Hz. something with a T= 220 ns has a main associated freq of 45.5 MHz.
See You
big5824
Tue Aug 31 2010, 11:26PM
f=1/T, where f is frequency and T is time period of one oscillation. Remember you need both values in SI units
Wed Sept 01 2010, 12:06AM
AleSeg wrote ...
See You
Bzzzt! Decimal point error!
1 / (220 ns) = 4.55 MHz.
Conversely, a frequency of 220 MHz has a period of 4.55 ns. Verstehen Sie?
zhgart
Wed Sept 01 2010, 02:48AM
zhgart Registered Member #3156 Joined: Wed Sept 01 2010, 02:19AM
what is "something that can't happen past 220 ns '?
Duality
Wed Sept 01 2010, 03:52PM
zhgart wrote ...
lets say a switch that can't switch faster then 220 ns.
Mattski
Wed Sept 01 2010, 10:32PM
R v.d. Tuuk wrote ...
Sort of, it depends on the shape of the waveform really. If a switch can switch on and off with a 220ns period then the "fundamental" frequency is indeed 4.5MHz as Klugesmith notes. But in order to have a nice square waveform at 4.5MHz, your switch needs to be working well at odd harmonics of the fundamental frequency: 13.5MHz, 22.5MHz, 31.5MHz, etc. That's because of the fourier series of a square wave. The series is infinite but because you need less amplitude in the higher harmonics, if they are attenuated it can still look pretty square. So if your waveform looks very square with a 220ns period then it could probably switch a sine wave at least at the 5th harmonic (22.5MHz) pretty well.
It's harder to make a square waveform because you need the higher frequency components as well as the fundamental tone. If your transistor is attenuating the higher frequency harmonics then your waveform will have a bigger rise/fall time and maybe some ripple and overshoot.
Look at Link2 which has this nice graphic: Link2 which shows a square wave vs. its fundamental tone, fundamental + 3rd harmonic, fund + 3rd + 5th, and fund + 3rd + 5th, + 7th.
Is this what you're trying to f igure out?
Duality
Thu Sept 02 2010, 06:11PM
so a square wave is basicly a sine wave with harmonics in it's planes? (just to see if i understood it correct.)
but i figured it out, i wanted to know the frequency if the wave had 220ns inter falls i was doing the math wrong i see, thanks all :)
ow and why do these harmonics have odd numbers? or can harmonics be even numbers like second and forth, what's this phenomena called?
Mattski
Thu Sept 02 2010, 08:25PM
Yes, any periodic (repeating) waveform no matter what the shape can be represented as a combination of sinusoids at frequencies which are harmonics of the fundamental frequency of the original wave. This is part of Fourier analysis.
It just so happens to work out for square waves when you do the math that they have all odd harmonics. But that is only true for certain special cases like square waves, triangle waves also have only odd harmonics but in different amounts. Most typical waveforms will be composed of both odd and even harmonics.
radiotech
Fri Sept 03 2010, 05:56AM
Perhaps the word wave should be explored. A sin or square is the periodic alternation in polarity at the lowest frequency we are considering. 1/f is the time for 1 alternation.
The problem with the square wave is it cannot be depicted on a time line. Time doesnt jump. 1/f - 3/↨ is the time for 1 alternation.
