  • Guests: 38
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Thinking about building a valve amp...
first  2 3 4 5
Thu Sept 09 2010, 08:18PM
Avalanche wrote ...
I've just been playing around with negative feedback, what would be the pros and cons of taking the feedback from before or after the AF transformer? I've tried both, just simple resistive only feedback with a decade box, and I thought feedback direct from the pentode seemed cleaner. I would think that taking it after the AF transformer would bring in problems with phase shift, and make the frequency response a bit less linear... I can see myself getting a bit hooked on feedback networks made with various components to try and get some nice tones.
AF Output transformers colour the output with their own particular spectral responses and oddities, so taking the negative feedback from after the transformer does a good job of ironing these out - and you'll notice your triode has been designed with more than enough gain to be able to give most of it away again in a negative feedback loop.
Here is a good quality negative feedback design of a triode-pentode amplifier from 1964 using the ECL86, a double valve similar to yours, but slightly more powerful:
1284063050 543 FT0 Ecl86 Amp 1964
You'll notice that the feedback circuit is in parallel with the load, and so will draw power. For this reason, you must make sure that the resistance of the feedback circuit is at least 10 times greater than the load impedance i.e. 80R if Zload is 8R.
radiotech
Thu Sept 09 2010, 11:16PM
[]that plus my heater center tap no longer being in the center[/b]
If this is an issue, a 100 ohm trim pot across the 6.3 volt winding with its wiper earthed will allow you to ground the midpoint center
electrically. (lift the actual centertap) The other thing is the EZ81
cathode magnetically couples the 100HZ pulses of RAW Ecc to the heater bus.
Also note the series resistor in the grid of Proud Mary's ECL86
circuit. This is used to de-snivet extremely hot tubes/layout issues
and leads to considering the grid circuit of class A anplifiers in terms of input admittance. Another tweak to response is to look at the screen bypass condenser and see if can be reduced, and what happens.
One thing that was said at a Syn-Aud-Con by Don Davis is that allthings done to reduce a noise dont add numerically. Sometimes the last thing you do cleans it up. On line AES tutorial recordings of Thiele & Small (124th) and Whitlock (on grounding) (126th) are great especially for valve amp builders.
Avalanche
Fri Sept 10 2010, 09:28PM
Quick update... a couple of hours of fiddling around, and implementing peoples latest suggestions and I have got some quite loud sounds out of the amp. I finally drew up a schematic as it is now, I have drawn schematics before but never posted them because it keeps changing as I figure out what's going on!
It is now starting to look more and more like a cross between Proud Mary's circuit above, and this circuit which I found Link2
The heaters are now at 6.3VAC with the center tap in the center. I have added feedback from the speaker, but noticed the volume was too low with a decent amount of feedback. It looked like the triode stage didn't have enough gain - I was using just the 2k2 cathode resistor with no AF bypass. After adding the AF bypass and extra resistor as in the schematic Proud Mary posted, I managed to get a decent amplitude with quite a lot of feedback.
I also decoupled the screen grid supply by adding the 4k7 resistor and the .47u capacitor (previously my screen was just tied to HT) I'm not sure if it's a problem, but I can now see my AF waveform on the screen grid with a (maximum) peak to peak amplitude of about 10v.
I've been testing with 2 speakers as shown - the 1950's speaker sounds the best, but only with certain types of music. It sounds fantastic with the guitar, just a shame I can't play!
1284154134 103 FT95594 Schematic1
1284154134 103 FT95594 Img 5215 Large
1284154134 103 FT95594 Img 5212 Large
Fri Sept 10 2010, 11:03PM
Have you some particular reason for not decoupling the triode anode supply - done in the circuit I posted with the 47k decoupling resistor and its 16uF electrolytic? With the pentode section tugging on the same supply line, not decoupling seems like an invitation to instability.
Heater wires should always be twisted together.
All wires and leads should be as short as possible.
If hum is a problem, try using shielded wire in the triode grid circuit.
Solder a copper shielding strip across the socket base to minimise interaction between triode and pentode.
Use a full size screening can on the valve.
radiotech
Sat Sept 11 2010, 01:51AM
Some 9 pin sockets have a centerpost on the terminal side in the center which if grounded acts as a bit of a shield and also a tiepoint for element parts which go to ground. Amplifiers can have either a ground tree of tie everything back to chassis lugs.
Another thing about production of amplifiers the output transformer was code blue red. Blue to the anode-red to Ecc. This makes sure all their products are phased the same.
When the transformer is working up around 15 kHz you might find that the winding terminal closest to the core has a different LC
model than the outer terminal depending on the coil build. Another reason to connect this to Ecc.. Also-Bigger amps) when some clutz
disconnects the speaker and then cranks the level to see why he cant hear anything, smoke results often- The valve socket flashes-(lucky) or the output transformer may ark to core if the core end is on the anode. (unlucky)
Another fine point: capacitors have an outer foil. If coupling grid to anode the anode is closer to ground, impedance wise, than is the following grid, So the outer foil to the anode would make the coupling shielded as it were.
Prowd Mary said transformers color the output. So do signal path capacitors, this is being found more and more, now that sophisticated measuring gear is common place. they have twist pecularities at certain frequencies. If in the feedback path- worse.
Just a point about the choke. A good experiment would be to replace that shunt resistor with a 1.5 ufd AC or paper cap and see if your voltage &or ripple improves.
Sat Sept 11 2010, 02:08AM
Looks cool! Is that your home workshop Avalanche, it seems quite well equipped.
The blue/red thing is only true in the USA, which had the RETMA colour code for wiring. Elsewhere in the world there was no standard colour code.
The problem of running a valve amp with the speaker disconnected is a real one. A 220 ohm resistor across the speaker terminals can help. Maybe. Sometimes.
The outer foil thing for coupling capacitors is suspect. Just think, the outer foil is connected to the inner one by... a capacitor! If it's a coupling capacitor in an audio amp, then it'll have a low impedance at 60Hz, so it doesn't matter a bit which end you connect where: it'll pick up hum just the same.
I don't really believe in "capacitor sound" either. tongue
radiotech
Sat Sept 11 2010, 08:38AM
Belief in "capacitor sound' -- Link2
Douglas Self went into this in the "master workshop on linear audio amplifier design" at the 124th AES and his talk snd slides can be watched and heard on their tutorial series on line.
The common destroyer/colorer of audio is the speaker, but in the measurements that be done today, small things can be hunted down and capacitors often are the cause.
In disgustingly aged audio gear, if it works, the practice of re-capping it just to be sure, can alter the sound, because the capacitors were lousy when they were made, but that's what they used, particularly paper. Throwing in a slew of mylars with no leakage
could shift the operating point of valves.
Avalanche
Sat Sept 11 2010, 09:36PM
Steve : yes it's my home workshop you see in the pics, I got fed up with lashing up things like power supplies, batteries and 555 timers every time I wanted to do anything, so I splashed out for some half decent equipment.
This feedback thing has got me a bit hooked, and I've been playing around with it all day. To start with, I cleared up a lot of the noise just by tidying up the wiring - totally underestimated the importance of that, what an amazing difference, no whistle anymore. Decoupled the triode supply with a 22k resistor and 100uF, no mains hum anymore. Totally silent... Yes!
Anyway I couldn't for the life of me get it sounding right with resistive feedback from the speaker to the triode. Many times I thought I'd cracked it, and I was down to just 147ohms at one point, but then I would put another song on and it would sound awful, or the resistor value would change just for that song. I settled for 147ohms in the end, and then wired in my volume control. I soon noticed that there was a lot of 'noise' on the anode waveform of the triode, that disappeared when at full volume. I zoomed into this noise and it was oscillation at about 24Khz. A 220pF cap from the pentode's anode to the triode cured this, but I still couldn't get it sounding right between different songs, and it was driving me mad!
I decided to get a bit more scientific and look at the phase shift between the input and output (after the AF transformer). I removed all the feedback, and ran the amp open-loop.
1284239869 103 FT95594 Phaseshift
I think this explains the oscillation - if we say there is about 90 degrees of shift at 13Khz, then oscillation at 26Khz (speaker only feedback) sounds about right. It looks like I'll need more than a simple resistive feedback from speaker to get it sounding right across the entire audio range...
The next pic is open loop frequency response, I guess the falling off towards the end is mostly caused by the AF transformer. Not sure how well this is supposed to 'self compensate' for the above phase shift with resistive only feedback?
1284240175 103 FT95594 Freqresponseopenloop
Next picture is with the feedback reconnected as it was before I gave up messing about with it - 220pF from pentode anode to triode, and 147ohms from speaker to triode. It peaks at 9.7Khz and sounds awful with some songs (it's clean except when there's 'a lot going on' then it goes crunchy).
1284240418 103 FT95594 Freqresponse Withfeedbackback
Phew... I think I need to learn more about feedback. Didn't expect I would get this hooked. If I can get it reasonably hi-fi I'll be happy, but I don't know how much I'm limiting myself with my choice of components.
I have accidentally run it without the speakers a couple of times, but fortunately no smoke! Yet! cheesey
Sat Sept 11 2010, 11:20PM
If you measure R and L of the O/P transformer primary, then you will be able to calculate its impedance at 3kHz.
The datasheet figure of 5.2V RMS on the pentode g1 for 2.5W output depends on Ra being 7k5 at 200V supply.
As E = sqrt(2.5 x 7500), in normal operation 137V should be developed across the primary, giving an amplification factor A of 137/5.2 = 26.
As the Miller effect shunt capacitance of the pentode depends on the value of A, we cannot determine the frequency response until
you have calculated the impedance of the primary at a nominal 3kHz.
radiotech
Sun Sept 12 2010, 02:16AM
The whole point of a pentode is to eliminate the the miller effect of the amplification in a triode changing the plate -grid degeneration
due to capacitance. Thats what the screen grid does. a good paper on the miller effect on the triode is here, as applied to music amps. Link2
Your open loop power curve looks fairly decent- if you changed the
power levels to db- its with 3db from ~~100-8000 Hz which in reality is all those little single ended stages ever do in practice-what can your speaker do? (asssuming its true RMS which you cannot judge on a scope)
Why it sould crappy is likely IM distortion the screen voltage tweeks that a bit There should be lots of old SMPTE analysers kicking about- (IM 60 hz modulating 8000).
Have you had those old ECF83s tested?
I think Langford-Smith is scanned on the net somewhere-at any rate here's why it doesn't sound right. note the dissonant parts mid range.
just a tweak- try about 1500 pF across the primary of the output transformer and see how it sounds.
1284257806 2463 FT95594 Scan0023
first  2 3 4 5
