  • Guests: 54
08/24 voltek (49)
08/24 DJ Cosmo (17)
08/24 n8 (39)
New sstc/drsstc
Gregory
Tue Aug 31 2010, 02:45PM Print
29/08/2010
Oops, now come to present my newest project, being developed by me, Grégory Gusberti, and my friend Gregory Pavan, with the goal of building a SSTC can easily be upgraded to a small drsstc, which is our ultimate goal.
Project Objectives:
- Develop an electronic part and reliable power.
- Compress the size of a system for easy transport.
- Be easy to upgrade, to turn a drsstc.
- Create interesting sparks with low consumption.
- Input for external interrupt signal with BNC plug for coaxial cable.
- Electronics for power factor correction.
So far we do the following:
- Compress the system in a timber of 25x25cm and 13cm high.
- Modular audio PRF by using a MIDI switch developed by me.
- Electronic power factor correction - 50%.
- Reliable, yes, the system is reliable but for SSTC.
- BNC-Plug successfully installed, pull-down resistor was also added if there is no signal at the input.
Photos
ThThThThThThTh
Here's a video that shows some pieces of construction and the first results:
http://www.youtube.com/watch?v=F4xZRhVOW_Q
NEW! 30/08/2010
Photos of the new MIDI system, now much more compact, rugged and portable!
- Lighter and smaller.
- Powered by internal battery.
- Soon to output to two coils.
- Output Connectors BNC, robustness and reliability in the signal.
- Entry USB plug and play, makes the conversion to MIDI already internally.
Photos:
ThThThTh
