  • Guests: 42
Seperate circuits
1 2 3 4
Adam Munich
Tue Aug 31 2010, 04:48AM Print
Putting two MOT primaries in parallel on one 120V 15A outlet is certainly not an option, so I was wondering about hooking each one up to a different circuit via an extension cord. Are there any concerns (aside from crossing hot wires!) I must worry about? I can't think of any ATM. (the secondaries are going to go in series BTW)
dmg
Tue Aug 31 2010, 04:54AM
I dont see why you shouldnt be able to do this, some household wiering (maybe in kitchens?)
have 2 hots, with a common nuetral, but each one is from a seperate 15A breaker,
perhaps you can these type of sources, and wire a mot to each socket in the outlet.
Tue Aug 31 2010, 05:00AM
Gatedbreakdown wrote ...
i second GatedBreakdown's point use a 240vac line.
Adam Munich
Tue Aug 31 2010, 05:08AM
I don't have a 240VAC line installed, and my kitchen only has 1 hot. The other one went dead when a nail severed a wire when we re-sided our house.
If each primary is plugged into a separate outlet in separate circuit, I don't see any problems that could result...
Tue Aug 31 2010, 05:21AM
Grenadier wrote ...
perfect nail...lol!
any way youll have to find two different lines with your desired phasing, it is possible. watch your phasing dots.
Adam Munich
Tue Aug 31 2010, 05:24AM
I've never seen an MOT with phasing dots. At least none of mine have any.
Tue Aug 31 2010, 05:32AM
you better figure it out. if you dont have them anti phased you wont get output, i think.
(both outs will be [+ against +]and [- against -] instead of [+ against -] and [- against +] right?)
be careful, try not to die.
Adam Munich
Tue Aug 31 2010, 05:33AM
I doubt I'll die, but it'll be quite a spectacular light show if it's wrong!
Tue Aug 31 2010, 05:35AM
Grenadier wrote ...
LOL!
Tue Aug 31 2010, 03:58PM
In case you didn't get the point about phasing,
when you choose two household outlets fed by different circuits:
The neutral wires will be at about the same potential.
But depending on the panel placement of the two circuit breakers or fuses,
your 120V "hot" wires could be same or opposite phase.
Your MOT primary connections must be phased accordingly.
If you get it wrong, the voltages of series-connected secondary
windings will subtract instead of add. No fireworks.
If one breaker trips (or has tripped) while you have a load or arc between the
two HV secondary terminals, all outlets on the tripped circuit
will be back-fed with voltage from a MOT running in reverse.
