  • Guests: 68
High Voltage Source
genious 7
Mon Aug 30 2010, 09:38PM Print
genious 7 Registered Member #2887 Joined: Sat May 29 2010, 11:10PM
I'm trying to obtain a high voltage, low current source (<3ma). I can use either a flyback or a MOT. In the case of a MOT, I have several diodes, so I could make a multiplier.
My question is: which should I use the Mot+ multiplier or the flyback (DC flyback by the way).
If using the flyback, what driver do you recommend, voltage wise (ZVS, 555, resonant 555)?
I'm going to use the setup mainly to draw some arcs, although I might use it to charge homemade capacitors.
There isn't a specific voltage I want to get, just as high as I can (within the reasonable) get.
Plasmana
Mon Aug 30 2010, 09:52PM
Plasmana Registered Member #3108 Joined: Thu Aug 12 2010, 05:37PM
If you are looking for low current HV source, then the resonance 555 driver is the best way to go. Normal 555 drivers are rubbish. wink
ZVS driver will give out more current and make more impressive arcs however, the output voltage is less.
Heres an schematic of the resonance 555 driver I had success with
Matt Edwards
Wed Sept 01 2010, 11:13PM
Do the two 100K resistors from Pins 2/7 of the 555 connect to 0v?
genious 7
Thu Sept 02 2010, 02:30AM
No, the leg of the 100k potentiometers are left disconnected.
Matt Edwards
Thu Sept 02 2010, 04:54PM
Ah, silly mistake. I didn't notice they were pots...
Thu Sept 02 2010, 09:33PM
The resistor-capacitor-diode snubber serves no purpose in that circuit. I'm the author of the original "quasi-resonant" driver concept by the way...
Matt Edwards
Thu Sept 02 2010, 10:32PM
If that is the case then perhaps you could post the original circuit so that rookies like myself can give it a try.
Fri Sept 03 2010, 07:53AM
Ok here is the circuit, the simple version: Link2
Plasmana
Fri Sept 03 2010, 10:11AM
Dr. Kilovolt wrote ...
Ah okay, that I didn't know, I was experimenting what happens if I put this here and that there smile
I don't know why, but the snubber circuit allows me to stretch the arc even further.
genious 7
Sat Sept 04 2010, 06:57PM
I found this driver. Between Dr. Kilovolt's driver and that one, which one would you recommend voltage wise?
Edit: found this one as well. same question.
