  • Guests: 54
10/09 sbs_2010 (34)
10/09 SoundDoc (50)
10/10 Ryan Parle (44)
Digital picture frame PCB etcher
Mon Aug 30 2010, 07:11PM Print
Hi.
This thread documents my attempts to build a PCB etcher using a Sweex digital picture frame, a LOT of SMD UV LEDs (only way to get reliable light spread without a lossy diffuser), an old touchpad pcb with the plastic removed, and some ingenuity.
I chose this particular frame because among its other features it has the ability to "stick" on one picture without doing that annoying frame transition thing which others do, so staying stable for 15 minutes is no problem.
started building the LED panel, unfortunately ran out of micro gauge solder so will need to obtain some more.. any ideas?
as you can see the picture quality is excellent for a £7.99 device, even though the colour may be a problem i hope to get around this using some very basic image editing.
Comments?
-A
"Bother" said Pooh, as he misspoke the words and the Army of the Dead awoke..
1283195478 96 FT0 Picframe
1283195478 96 FT0 Sweexguts
1283195478 96 FT0 Mouseboard
1283195478 96 FT0 Mouseback
1283195478 96 FT0 Ledpanel
1283195478 96 FT0 Startsoldering
1283195478 96 FT0 Ledclose
Mon Aug 30 2010, 08:25PM
You're an ingenious fellow, Andre!
The other day, I noticed I had a bottle of potassium dischromate on a shelf that I hadn't looked at for a long time, which put me in mind of the 'gum dichromate' photographic process, which might be of interest to you.
K2Cr2O7 is sensitive to light - though not nearly so much as silver halides - but nonetheless was used widely in early photographic printing, and until much more recently in the photo silk screen printing process. In brief, a paste made from the dichromate and any of a number of colloids will become hard when sufficiently exposed to strong light - forming a mask - whilst the unexposed areas remain soft and are readily washed off.
It goes without saying that hexavalent chromium compounds are known carcinogens, so steady as she goes.
Mon Aug 30 2010, 09:03PM
heh..
another thought, the uv reacting glue sold for repairing windscreen chips and cracks might harden if heated up to about 30C and exposed to UV from something like this..
could be a low cost alternative to expensive resist coated boards..
Adam Munich
Mon Aug 30 2010, 11:43PM
I've got some micro gauge solder, though why didn't you just get a high power UV led? Digikey has some ~350nm ones that put out quite a lot of light.
Tue Aug 31 2010, 12:14AM
Conundrum wrote ...
heh..
I believe there's quite a range of UV engineering adhesives, though I have no experience of them.
Kilham
Tue Aug 31 2010, 12:27AM
Kilham Registered Member #2814 Joined: Wed Apr 21 2010, 12:28PM
Screen printable UV curable inks are available, even solder resist. You just flood coat the board, oven dry it and expose to UV. Problem is they're about £70 a litre from Mega and I haven't as yet found a cheaper source.
What kind of resolution / board size do you anticipate it will be capable of?.
Tue Aug 31 2010, 07:09PM
may not be a problem as i could mount the display on an x/y movable block.
this might also get around the lack of pixels..
-A
Adam Munich
Tue Aug 31 2010, 10:02PM
Corundum, this is kind of important...
Will the LCD even allow UV to pass?!
Kilham
Tue Aug 31 2010, 10:09PM
It's Conundrum, he's not usually an abrasive poster wink
The display glass will be quite thin, it will attenuate the UV but hopefully not by a significant amount. Avoiding a lossy diffuser may provide enough to compensate for the loss through the display.
Tue Aug 31 2010, 11:48PM
Martin King Registered Member #3040 Joined: Tue Jul 27 2010, 03:15PM
Kilham wrote ...
It doesn't take a lot to attenuate UV significantly. When I built my double sided exposure box I found I couldn't get acceptable exposure on both sides due to the fact that the mylar pulldown sheet on the top side was attenuating the UV more than the bottom side (no mylar) so I had to add a mylar sheet to the bottom side just to balance the light levels. I hope the LCD does work but I also hope the basic principle was tested with a small display first before spending too much time/money on it? Personally I use Inkjet transparencies cheap and easy.
