  • Guests: 54
new drsstc
Gregory
Mon Aug 30 2010, 05:05PM Print
I'm working in a new sstc that will be a small drsstc, i have here the irg4pc50ud igbt. I want to know if this igbt run at 270khz, because this is the frequency of my secondary?
see a video of the construction and the firsts results of the project:
click here
Mon Aug 30 2010, 06:35PM
Thats iffy. The big thing will be how well your DRSSTC will soft-switch as well as how good you can take the heat out of this device. If you get a good tune, with short pulsewidth, than you should be okay.
Hard switching - its rated only to 40kHz, but for resonant switching (which a properly tuned and set-up DRSSTC should do with zero crossing current), it states operation 200kHz+.
Can you reduce the fres? 100kHz would really reduce switching losses and you can get this with a secondary with finer wire.
Gregory
Mon Aug 30 2010, 06:38PM
yeah, i will remake the secondary with 30awg wire, a think that it will have 100khz
sorry the double post, I will use a pentium 4 cooler with heatsink for each igbt, do you think that it's good?
Tue Aug 31 2010, 03:16PM
I always recommend a heatsink that has lots of mass to it - like a solid chunk of aluminum with fins. Also, be sure to have a good thermal interface, such as thermal grease etc... Very important!
Also, note the transient heating (pulse-by-pulse) of the die may be more of a concern than steady-state heating. In this case, running at lower pulsewidths would be beneficial to minimizing the pulse transient heating of the die.
Gregory
Tue Aug 31 2010, 04:25PM
my interrupter max pulse width is 250us and 280bps, i think that is 10% of duty in maximiun operation.
do you think that a pentium4 heatsink with cooler for each igbt isn't good?
Tue Aug 31 2010, 05:11PM
Thats way too much IMHO.
Limit to 100Hz PRF and pulsewidth to maybe 150us.
Gregory
Tue Aug 31 2010, 05:12PM
i will try, but i think that i will have small sparks
Goodchild
Tue Aug 31 2010, 05:53PM
If you build and tune it right you should not need more than 100uS. I have coils that pump out 5 feet at 100uS if you want big sparks the key thing is a high bus voltage, 400VDC+ (for full bridge) 800VDC+ (for half bridge) and good tuning.
Gregory
Tue Aug 31 2010, 05:57PM
it's a small coil, with 50cm i will stay happy! i don'y now if the pentium4 heatsink is good...
Wed Sept 01 2010, 12:18PM
I agree. If you have a good tuning point you don't need much pulsewidth.
My microBrute DRSSTC Kit (which stands only 11 inches tall) with a proper tune can produce over 20" arc (with a perfect tune) at only 85us with about 300VDC bus voltage. Key is to have a really good tune point.
