  • Guests: 58
Amazing chinese portable gas lamp!
Muttyfutty!
Sat Aug 28 2010, 05:03PM Print
Muttyfutty! Registered Member #2915 Joined: Fri Jun 11 2010, 10:41AM
I was browsing through the random junk at the hardware store the
other day when I came across this interesting find:
1283013454 2915 FT0 Dscn2625
It was explained to me that this was some kind of Chinese lamp that used a
chemical combined with water to generate a highly flammable (inflammable?) gas.
This is the ‘Fuel’ :
1283013490 2915 FT0 Dscn2627
When combined with even a small amount of water it starts fizzing violently and
heats up rapidly due to (I assume) the generation of gas being an exothermic reaction.
1283013563 2915 FT0 Dscn2629
1283014841 2915 FT0 Dscn2626
When placed in the corresponding containers in the lamp the gas is funneled up
through the ‘chimney’ and lit at the end, producing an surprisingly bright light
1283013638 2915 FT0 Dscn2638
1283013638 2915 FT0 Fscn2641
I personally thought this was really good, and, as it turns out, the natives of
Malaysia have been using this method of lighting for over 50 years.
This thing can last for literally 2-3 hours on one piece of 'fuel' about the size of a 5W ceramic resistor
And any idea what the “Fuel” may be? I have no Idea, it seems to be a rock like consistency.
When you break it in two you can see crystal like formations inside…
Any thoughts?
Sat Aug 28 2010, 05:18PM
The chemical is calcium carbide (CaC2), and the flammable gas is acetylene (C2H2).
Carbide acetylene lamps were routinely used as bicycle lights and miners' headlamps in England until the 1960s, because they will not fail if they get wet.
Hon1nbo
Sat Aug 28 2010, 05:58PM
A bit of other info about this chemical, in addition to the description by Mary.
the chemical also used to be a component of a novelty toy (and some serious big brothers) which are Salute Cannons, meaning they were meant to make a loud noise and not actually fire things (though it does work as a spud gun fuel). It is also known as "Bangsit" for its use in these things
-Jimmy
Sun Aug 29 2010, 12:46AM
The carbide lamp worked much in the same way as Kipps' famous H2S Apparatus - water drips down from the upper reservoir onto the rock hard calcium carbide chunks in the lower chamber. Acetyleme gas is generated by the reaction CaC2 + 2 H2O → C2H2 + Ca(OH)2, and the gas pressure forces the water back up into the reservoir, stopping the reaction until the pressure falls again when more water will feed by gravity into the reaction chamber. Eventually a point of equilibrium is reached whereby water descends and reacts anew to replace the gas lost from the chamber via the flame nozzle. If the flame is turned low, then more water will be forced back up into the reservoir, and vice versa.
1283042041 543 FT0 Carbide Miners Lamp
The igniter fixed into the reflector worked in the same way as a petrol cigarette lighter - the steel wheel was spun with the thumb against a 'flint' - cerium Mischmetall, or ferrocerium, I think.
radiotech
Sun Aug 29 2010, 02:43AM
Acetylene generators were found in welding shops too before they discovered that the gas could be kept under pressure in a tank containing acetone. If you compres it otherwise it blows up. Our old welder had one standing in his shop.
Calcium carbide was sold in tins and evil children (so I've been told) used to dump it into catch basins on streets and toss a match in.
