  • Guests: 57
How to run an TL494 halfbridge driver at higher input voltage?
Plasmana
Fri Aug 27 2010, 05:54PM Print
Plasmana Registered Member #3108 Joined: Thu Aug 12 2010, 05:37PM
Hi all,
After weeks of researching and experimenting, I finally got a flyback being driven by an TL494 halfbridge driver working beautifully! It is based on Mads Barnkob's work: Link2
It works well up to 160VDC making large white fiery arcs and the IFRP450's stays relatively cool after short runs.
The problem is when I increase the input voltage to 200VDC, the arcs starts getting a little bit too long for my taste, the MOSFET's heats up more quickly than I wished it to and i don't want to risk burning out my one-and-only 2A variac.
So basically, how do I run this driver at 325VDC without blowing up anything? I want to be able to power it directly off the mains in the UK.
Marko
Fri Aug 27 2010, 10:47PM
Hi,
to me it looks like your flyback is getting saturated. How many turns are you using for your primary winding? I found 60 to 80 turns to work well for 325V DC. I used frequency of 66kHz. You'll probably either have to increase your working frequency or increase the number of primary turns.
Marko
cjk2
Sat Aug 28 2010, 02:38AM
Try doubling your number of primary turns as a starting point.
Plasmana
Sat Aug 28 2010, 09:18AM
Ah! I forgot about people used a lot more primary turns than 'usual'. I used 15 turns for primary suprised
It all makes sense now, Ill add more primary turns.
Thanks guys!
Osama Ma'mon
Sat Aug 28 2010, 09:44PM
Osama Ma'mon Registered Member #3144 Joined: Fri Aug 27 2010, 01:44PM
change the capacitor to 220uf 400v and the mosfets to irfp460
use 25 turns for primary
Plasmana
Sun Aug 29 2010, 08:21AM
Osama Ma'mon wrote ...
Why 220uF capacitor? I am planing to build a 1000uF capacitor bank out of various 450v capacitors I got lying around to get rid most of the buzzing noise to make this driver audio modulated.
Osama Ma'mon
Sun Aug 29 2010, 12:28PM
you want to make halfbridge fly back driver with out noise
ok
i well uploade the driver
Osama Ma'mon
Sun Aug 29 2010, 12:45PM
use this circuit withe your tl494 audio driver
1283085919 3144 FT95316 Osamaq
Osama Ma'mon
Sun Aug 29 2010, 12:47PM
the capcitor bank connected in paralell with the out of bridge
