  • Guests: 71
this igbt is good?
Gregory
Thu Aug 26 2010, 06:30PM Print
i want to make a middle drsstc, can i use this igbt? CM-200DY-12H
the fres of the secondary is around 60khz and the primary i want to run at 50khz
Thu Aug 26 2010, 10:51PM
If I recall, this should be okay for a small to mid-sized DRSSTC. Although, if your fres is around 50-60kHz, your coil must be really large.
You'd probably be better off using a CM300 dual or two CM600's for something larger.
Gregory
Fri Aug 27 2010, 07:45PM
i am thinking in use ixys mini-brick 60n60
Sparcz
Thu Sept 02 2010, 04:22AM
Sparcz Registered Member #2419 Joined: Mon Oct 05 2009, 07:29AM
I keep seeing that people are using 4) CM600s for their SSTCs.
Are they really paying the Digikey price of over $200 each?
Or is there an alternate cheaper source?
Same thing for the 942C caps. Are people really paying $7 each for these?
dmg
Thu Sept 02 2010, 04:40AM
If you want to buy them at that price, you are more then welcome to, but there is other cheaper sources for said parts, one bieng ebay, or locally (my case atleast).
but yes, there are cheaper sources, and even cheaper parts that can make a good substitute to the CM600 or the capacitors.
