  • Guests: 55
Oddly marked transformer
brockolicious
Tue Aug 17 2010, 02:53AM Print
brockolicious Registered Member #662 Joined: Sat Apr 21 2007, 06:58PM
Hello,
I came across this transformer intended for neon signs, but the specifications on its label are a little confusing. It says 4000V and 110ma but the wattage is 3W. It's obviously not 3 Watts, but it looks too small to be 440W. Any ideas?
2mx25n7
Thanks
Myke
Tue Aug 17 2010, 05:18AM
As you load the transformer, the voltage output drops so the output will either be max 4kV 0mA to 0V at 110mA. Somewhere in between these two extremes, the product of the current and voltage should be about 3. I guess.
radiotech
Tue Aug 17 2010, 06:24AM
If you multiply 0.11 A by 120 V you get 13 Watts which is a reasonable power level if the neon tube was connected and was running at 2000 volts and 7 mA. ( 50% voltage operating on secondary. ) 13 watts sounds reasonable for one of those neon bar- stand-alones. I've got 2, one in the shape of a beer bottle , the other a cocktail glass.
Did the 1 get rubbed off?
