  • Guests: 33
Tesla coil in the rain
Thu Aug 12 2010, 07:52PM Print
Martin King Registered Member #3040 Joined: Tue Jul 27 2010, 03:15PM
It's possible that the coil I'm currently building may end up being used in outdoor shows at some point in the future. Now assuming that all the electronics are thoroughly waterproofed (without compromising cooling) and only the Primary, secondary and top load are exposed to rain is there likely to be a any problems using it in drizzle/light or maybe even heavier rain ? I guess I'd need to drill some drainage holes in the flat part of the toroid (or change to a spherical top load), another possibility would be to put a plastic tube around both the coils so that only the top load is exposed to the elements.
Cheers,
Martin.
Goodchild
Thu Aug 12 2010, 08:03PM
I don't see running a Tesla coil in the rain to be very safe.
Thu Aug 12 2010, 08:11PM
Goodchild wrote ...
Why do you think it would be dangerous? Any remote controls would have to be completely isolated (fibre) and probably an isolation transformer on the mains but then for a show with a live audience then I would want everything to be isolated regardless of rain or not. I'm reasonably happy a coil could be operated safely in rain with the right precautions, it's more a case of would it actually work/produce sparks in the same manner as dry conditions, would rain affect the tuning of the coil adversely, that sort of thing.
Martin.
modularduck
Thu Aug 12 2010, 09:26PM
modularduck Registered Member #3094 Joined: Tue Aug 10 2010, 03:12AM
I would think that standing water would be an issue and might cause errant voltage to travel long distances and endanger people even if they were quite a way from the coil its self. i.e. if you got a ground strike from the coil it could shock someone standing in a puddle some distance away. but perhaps i am wrong in this
Thu Aug 12 2010, 09:39PM
modularduck wrote ...
Thanks that's the sort of thought through reply I'm interested in rather than a knee jerk "it's dangerous". My gut feeling is that once the spark hits ground that's pretty much it, electricity takes the easiest path to ground and that's not likely to be via a punter standing several tens of metres away. If it was an issue then I suspect a ring of copper pipe/wire around the coil at around it's maximum strike distance at ground level and attached to an earth spike (effectively another strike rail) would prevent any problems, otherwise the coil could be operated in a chicken wire Faraday cage but I'd rather avoid a cage.
Goodchild
Thu Aug 12 2010, 11:15PM
It's not just that, but water can be very conductive at high voltages if it got in the wrong place at the wrong time I can see it shorting things in the coil and/or the power supply.
Over all electricity and water don't mix.
You wouldn't get in a bath tub with a toaster would you? It's the same way I wouldn't get in the rain with a tesla coil.
Just my thoughts.
Killa-X
Thu Aug 12 2010, 11:44PM
I always thought of this too, but would agree with Goodchild, yet I always wonder how a Tesla Coil would react in rain. Would the streamers just act normally, arcing random to air, and the rain does nothing because they arnt a 'shorter path to ground' so to speak, or would the streamers arc the raindrops?
Xplorer
Fri Aug 13 2010, 01:12AM
Xplorer Registered Member #2416 Joined: Sun Oct 04 2009, 04:23AM
If the secondary form gets wet it will likely conduct the HV streamers down to the primary circuit.
-Tony
Andyman
Fri Aug 13 2010, 01:20AM
^ That would be my main concern as well. Unless you covered the primary and secondary with some sort of highly hydrophobic material...
radiotech
Fri Aug 13 2010, 03:02AM
Step potential is the issue. If a high voltage line contacts earth live, and they do quite often in storms on unfused circuits that can dump tens of amps , the volts per meter on the surface can immobilize someone walking close by. This happens because the resistance of the earth, between to points approximating the distance beween two feet striding, will drop a high enough voltage, given the current flowing from the fault.
This cant happen in switchyards or substations or along the fence because under the surface
is network of bonded copper conductors and ground roda,(have built these)
A telephone magneto can send 10s of MILLIAMPS for miles through earth as return of a metalic side. But that is only because of the nature of earth resistance. This current can annoy earthworms up as fishermen know. if they look around the ground rods.
A streamer from a big Tesla coil might be able to output nasty, though not lethal current if the streamer and earth return impedance matched the output impedance of the coil and allowed the coil to stay resonant. As to 'step potential, not likely, for reasons stated above,
The multi-joule high voltage generators are a different story, if one of those discharged through earth in the rain, hard to explain stuff might happen, not lethal, but could cause injury if somone jumped or fell when they got zapped. (seen this)
Goodchild has some good points about what we do in the rain or water.
If you were running a TC in the rain and an incident happened, you would be hard preesed to explain you weren't responsible.
