  • Guests: 68
Hugo Gernsback's Tesla Coil
radiotech
Mon Aug 09 2010, 04:32PM Print
Here's an old coil plan that someone might want to construct, if only to highlight the use of o Model T spark coil,
1281371568 2463 FT0 Scan0006
1281371568 2463 FT0 Fordcoil
quicksilver
Mon Aug 09 2010, 05:37PM
I have heard of this before but are Mod T spark coils even available as per the original design as working systems? I've seen these:
But Many do not indicate whether they are simply old examples or functional. They look seriously beat and are seemingly too cheap to be true.....
radiotech
Mon Aug 09 2010, 07:05PM
You'd have to buy one to find out. Most, I suspect are good.The reason is simply back then no one kept a bad one. Also the points set was available seperately. They can be opened and repaired-- the wood box is full of black tar.
Also they were used years after Kettering Ignition for other things.
I found 2 in a naval Pelorus chart recorder. We used an earphone ground fault tester that used a Ford assembly to trace shorts in power cables,
Note the weight extension on the interrupter of the coil to slow it down from a buzz to a pulse.
Note the Gernbacks books were reprinted 30 years ago by Lindsay Publications in their original booklet form., however I am scanning an original with expired copyright,(1938) not the reprint.
1281380744 2463 FT94165 Scan0005
1281380744 2463 FT94165 Scan0007
