  • Guests: 42
M.A.D. (32)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Two amplifier / PSU boxes in heatsink enclosures with transformers
Dr. Slack
Sat Aug 07 2010, 09:00AM Print
Two gutted metcal units, about 220mm high and 115mm square outside, 90x105x200 inside, weight 2.7kg. Ideal for making tidy power supplies or power amps
You get ...
a) extruded heatsink case, with ends
b) power device carrier with several drillings, one is for TO3, which fits inside the case, also carries the power inlet connector and a coax/cable output point
c) 80VA transformer with 115/230 primary and 2x14v secondaries carried on the bottom end
d) a switch and a couple of LEDs on the top end
e) fused, filtered 6A IEC power inlet
Yours for postage (from UK) and a donation to 4HV
1281171543 72 FT0 Picture
Matt Edwards
Mon Aug 30 2010, 08:51PM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
How much are you looking for? I am sure that shipping the the US will be a bit expensive.
