  • Guests: 33
First Tesla coil, have question
Sam from louisiana
Thu Jul 29 2010, 02:04PM Print
Sam from louisiana Registered Member #3004 Joined: Fri Jul 16 2010, 01:45AM
I own a small neon company, and just recently discovered Tesla coils, and also just realized I have a huge stack of non-GFI transformers. I am working on designing my first coil, and Im lookin at all the plans and ideas.
I have a neon plant, and I can make neon units. Would It be a good idea to use a very small neon unit for a spark gap? or does the gap need to be open air?
Goodchild
Thu Jul 29 2010, 02:42PM
A neon tube will not work as a spark gap, the spark gap is acting as a switch and can't be inside a gas filed tube.
Myke
Thu Jul 29 2010, 03:17PM
I would think it would be possible but the tube should probably be at least atmospheric pressure to help quench the arc. You should use really heavy (probably solid) electrodes because they heat up from the arc. I don't know how you would deal with the expansion of the metal though because it might break the glass.
Sam from louisiana
Thu Jul 29 2010, 03:29PM
the metal in the electrodes is designed to be properly "burned in". When I make a neon unit, i suck most of the air out, leaving enough of a medium for the arc to travel through, and run about 500ma at 15kv to heat the unit up to 500 degrees F. I do that so the glass expands and releases any impurities stuck on the surface of the glass. The electrodes get red hot, and sustain the temp for 1min.
the metal expansion and heat should not be a problem.
Im really trying to understand how all this stuff works so when I build it, It comes out right. I see alot talk about Vaccuum tubes when I look up high voltage. I have a vaccuum pump, so Im trying to make the best of what I have to work with.
I am planning on running multiple transformers on this setup. I tested 3 of them today for compatability, and it worked out well. So I have a 12kv 90ma setup so far.
hvdavi
Thu Jul 29 2010, 03:51PM
hvdavi Registered Member #3046 Joined: Thu Jul 29 2010, 03:06PM
Hello my name is David I am Brazilian I am 13 years old and ask advice for you who already have a expience it because I'm riding my first tesla coil these are the Specs
transformer primary
Input 240v 60Hz
output voltage 8.4kv
the output current 0.3 amps
primary coil
inside diameter 4.124in
wire diameter 0.197in
total turns11.1
total diameter 4.68in
secondary coil
3.937in diameter
length 23.622in
24 gauge
1083 total turns
please help me
