  • Guests: 44
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Suggestions for cabling
IntraWinding
Fri Jul 23 2010, 04:45PM
coillah wrote ...
Here's a pic of my chamber I am building.
1279841224 1517 FT92744 My Senior Project Is Better Than Yours
Nice! What will you use it for?
doctor electrons
Fri Jul 23 2010, 09:12PM
doctor electrons Registered Member #2390 Joined: Sat Sept 26 2009, 02:04PM
I agree, that thing is pretty!! You should be ok with the zero awg at 150 amps as long as there won't
be any large inrush or surge currents that pass the cables rating.
radiotech
Sun Jul 25 2010, 06:56AM
Ampacity is a system of rating wire and cable insulation and their raceways on temperature of the environment they are in. It also has the effect through regulation of sizing hardware and overcurrent protection settings.
Regulations aside the sizing of the conductor just depends on what resistance you can tollerate. You may even desire the conductor to fuse under severe overload.
doctor electrons
Sun Jul 25 2010, 01:31PM
radiotech wrote ...
Yes. Yes. Agreed.
On this note! Overcurrent protection devices can also govern wire sizes. For example, say you have a large distribution block that carries
0 awg wire on its line side. The load side will not have any 0 awg connections and will usually be rated for a wire that is 14 awg minimum.
14 awg is only good for 15 amps, according to ul and nec. The reason this can be done "safely" is the condition that there is a specific
fuse type in front of that distribution block, usually class j, and over current devices like breakers after the block and before the loads.
This type of setup is what you will see in almost every industrial electrical panel. Sometimes the rules dont make any sense but after
carefully considering their reasoning they get a bit less foggy. There is also another wire sizing table in the nfpa70, have a look at that
one! It is completely different from the nec and ul tables!
radiotech
Sun Jul 25 2010, 03:50PM
The general rule is when ever a conductor is fed from a larger size conductor protection applies. Then there are the tap rules which forego protection based on length of tap. Example 30 amp wiring may feed a 30 amp disconnect close to a 1000 amp bus gutter. The reason is the top of disconnect may literaly explode if it fails but the enclosure will contain it. The tap circuit will clear leaving the bus operating. This is the reason electricians operated those disconnects in such a way so the door, if it blew open wouldn't smack them in the face. Nowadays arc flash protective suits must be located in switchrooms.
An interesting rule concerns firepumps. You can reduce protection on these circuits because you aren't worried about the pump motor catching fire if the building is on fire and the pump is delivering water to the sprinklers or hose stands
Most codes have "code handbooks" which are different from the code rule book, in that they state the reason for the rule.. History shows Edison simply stole the distribution plan for his system by finding out exactly how the system of gas pipes reduced their diameters along the way while fanning out to the houses from the mains.
Edison was angry at the arrogance of the lighting gas companies which drove him to perfect a system to overthrow their monopoly. Perhaps a new Edison will overthrow the oil cartel by making something that works for cars.
1280073039 2463 FT92744 Scan0003
doctor electrons
Mon Jul 26 2010, 02:27AM
That is the coolest danger sign i have ever seen!! That looks like an old book, i am a huge fan of old books!
I sure hope someone knocks the oil companies out of the drivers seat!! That would be a refreshing change.
I think these guys should worry less about how many billions of dollars they can pocket and more about
keeping the earth clean, while keeping money in our pockets. Thats a whole different thread!
Back to the convo, arc flash rules are increasing! I notice more and more at work. The latest and greatest is
putting on the space suit whenever we do testing on a live panel, along with the usual safety barrier in place around
the area. Friday i was told we now need to place arc flash warning labels (the ones with the ppe statements) on every
enclosure that it is fed with 50vac, 50vdc, or higher. I recently heard a rumor about state regulation getting larger.
Supposedly a license will be required to build any electrical equipment. This would be aside from the journeymans card
i already hold. In other words, non-state licensed individuals would not be allowed to work on any electrical equipment.
I suppose that is fine, just another 100 bucks to take a test and another 100 to renew every year.
Mon Jul 26 2010, 05:47AM
I didn't realize arc flash suits & warning signs are so prolific nowadays.
There's a lady I work with whose (now ex-) husband suffered life
altering burns in an arc flash accident 10 years ago.
doctor electrons
Mon Jul 26 2010, 09:38PM
Thank god he survived! Not only are many electricians killed by arc flash, they suffer miserably
before they pass on. I would assume this gentleman suffered the same way, and most likely still is.
I understand the need for protection and a lot of my fellow electricians complain. Some make comments like
"This damn suit makes my job more dangerous because i cant see a thing, these stupid gloves are like oven
mitts!!!" It does not bother me, i want to keep all of my fingers and both of my eyes. Oh yea, my face to!
radiotech
Mon Jul 26 2010, 10:56PM
The issue today is the advanced engineering of electrical gear, which makes it smaller, better and more dependant on proper application and operating procedures. Gone are the heavy contactors with mineral based insulation that could survive a minor sunburst and be repaired with just a few parts.
You add that to the difficulty in finding trained and long experienced electricians, the workplace safety people dont want to pay out the rehab/medical costs.
coillah
Mon Jul 26 2010, 11:59PM
coillah Registered Member #1517 Joined: Wed Jun 04 2008, 06:55AM
doctor electrons wrote ...
The load side will be purely resistive. On the high voltage side of the xfrmr I'll have a nice SCR power controller with soft start. It's amazing how much cheaper you can make these systems when you don't rely entirely on a distributor like KJL. All the components they sell are obscenely marked up (power controllers, wiring harnesses, transformers, even the evaporation plate)! Plus, I'll get more features from the equipment I found/ make on my own.
Still have an amazing amount of work left to do on this project though... Hopefully I can finish it before I graduate :D
