  • Guests: 35
12/29 Cprossu (40)
12/29 Kokamo (46)
12/29 GalliumMan (60)
Toroids: Conventional vs. Pipe Sections
UbuntuNinja
Thu Jul 15 2010, 01:27AM Print
UbuntuNinja Registered Member #2677 Joined: Mon Feb 08 2010, 03:06AM
I am building a medium power DRSSTC and need a 24"x6" toroid for the topload but can't afford to spend $350 on one but still want a toroid that is an interesting visual aspect of the coil as well as the actual electrical role so for a while I was stumped as to what I should do. However, after seeing the pipe toroid Finn Hammer used for his Thumper coil, I decided to try and apply the same technique to my coil. My question is as follows: is the capacitance of a toroid like Finn's equal to the sum of the capacitance values of the respective rings? If so, what is the cross section diameter of the whole toroid? Is it equal to the cross section of the individual pipe rings? Thanks!
Kizmo
Thu Jul 15 2010, 10:04AM
Im currently building similar toroid but instead of using few rings of thick pipe im going for several (30) rings of thinner round wire.
Few things about toroid surface integrity (or smoothness) are bothering me with this desing. Here is what i think after doing some testing and reading stuff from internet: (please correct me if im wrong)
- If toroid is small/medium size compared to rest of the coil it has to be very smooth
- Larger ROC allows rougher surface finish without losing performance (ring/wire mesh toroids etc)
Conclusion:
Toroid surface integrity is not critical if it has large enough ROC compared to height of an average surface features that are "sticking out" from imaginary perfect round surface. Other important thing is to desing toroid large enough that coil just barely power to break out with single streamer.
Btw toroid i started to build has major diameter of 150cm and minor 40cm :)
Thu Jul 15 2010, 11:30AM
Just use corrugated heating duct from your local Home Depot. Works great.
Killa-X
Fri Jul 16 2010, 01:50AM
Awhile back ago I saw someone put plaster on corrugated heating duct. they did multiple layers and smoothed it out, and the finished project was a smooth toroid. They then covered it in aluminum tape, and it looked really nice. I cant recall the site name or who it was at this moment...
Just came to me. Wall Filler.
I have plans to try this out for my next coil :)
Luca
Fri Jul 16 2010, 07:03AM
Luca Registered Member #2481 Joined: Mon Nov 23 2009, 03:07PM
Is it really important using a topload with a completely smooth surface?
I know that a corrugated surface increases corona effect but I wonder if the actual performance is really affected by such increase of corona losses... mistrust
On the other hand, a smooth toroid is really cool! shades
Regards,
Luca
Fri Jul 16 2010, 12:13PM
Usually a DRSSTC needs a breakout point - so a toroid with a rough corrugated surface is ok.
Fri Jul 16 2010, 12:39PM
Luca wrote ...
Regards,
Luca
Smooth toroids are not necessary. They do look better though.
Ed Wingate's famous magnifier use corrugated duct pipe covered with aluminum tape and rocked the house with at least 10-15 foot arcs, and i've seen individuals (photos) in Richard Hull's TCBOR group using things as diverse as Turkey Pans and Ventilation Caps for top loads.
UbuntuNinja
Sat Jul 17 2010, 12:40AM
Kizmo wrote ...
Conclusion:
As far as the size of the toroid vs the size of the coil and the effect on how smooth the thing has to be I think I am good. My seconday is roughly 6.25"x25". What is ROC? What is the chord/cross section diameter for a pipe toroid that is used in ScanTesla? How are you securing the wires to the frame of the toroid? The coil you are building the toroid for must be a monster!
