  • Guests: 33
IGBT hardware ooops...
dmg
Mon Jul 12 2010, 02:33AM Print
I may have underestimated my strength when I was screwing the terminals of the IGBT in, I seem to not be able to rest until all those philips heads are all lined up and facing the same way, "+++++" so I may have cranked the thing too hard,
the end result was in the image shown, I cracked a small piece of the material of the package, this was only a wall, I did not go past the epoxy cover, or exposed any part of the semiconductor, and Ive testing this IGBT, and it still works.
the question is, am I worried about nothing? or is this gonna bite me in the ass later down the road?
(also, the connection shown is the collector)
1278901995 2628 FT0 Oppsfuckedup
Anon01
Mon Jul 12 2010, 04:07AM
Anon01 Registered Member #1589 Joined: Sun Jul 13 2008, 06:40PM
I just cried a little. There was a little laughing as well...
It should be fine if nothing is exposed. I have one that was damaged in a very similar way from dropping it on concrete. As long as nothing is exposed it should be fine. (The MOSFET is still in service.)
dmg
Mon Jul 12 2010, 04:43AM
well, what about exess heating of that lead? the material sorounded it Ive noticed to disapate heat quite well, could this become an issue? (personally i dont think it will, im going to run pretty low duty through this bridge, and my 1/8 thick copper buss seems to disapate heat also well, so it will probably also act as a heatsink for that thin IGBT collector lead?
well, I think its no issue now anyway, just a cosmetic defect.
Avalanche
Mon Jul 12 2010, 08:52AM
It'll be fine, those packages are an awful design with their captive nut. It's asking for it. At work, we've sent equipment out that has nearly all of them cracked cheesey
Luca
Mon Jul 12 2010, 10:07AM
Luca Registered Member #2481 Joined: Mon Nov 23 2009, 03:07PM
I did the same mistake the first time I tried to screwing the terminals of similar IGBTs... angry
My intent was minimizing contact resistances...
Anyway, as long as the crack is limited to the zone around the nut without involving the body, it should be fine...
Regards,
Luca
dmg
Mon Jul 12 2010, 04:15PM
Well, after this little mishap, ive charged up the gate and tested the IGBT bascily, so far it works just as before with no issues. so I think it really shouldn't be an issue
Thank you everyone.
TheBoozer
Mon Jul 12 2010, 10:11PM
That's so funny to me. I usually break and strip stuff all the time. My problem is I am always after "super tight"... I really should get a torque wrench...
Anyhow, it's been quite a while since I serviced my half bridge of 60N60's... Sure enough, last time I serviced it, I shattered the ceramic also. LOL. Anyhow, I push this bridge past 500 amps all the time, and it's been operating "cracked up" for months. Hehehehe
Here's how "my" cracked guy runs : Link2
Rich
dmg
Mon Jul 12 2010, 10:48PM
Thats awsome Boozer, (nice miller in the background too! cheesey )
my IGBTs are well, 200GT60s, so hopefully ill be able to push a godload of amps through em as well. (im aiming 800 through em for now)
