  • Guests: 35
Can anyone help with info on this great find ??
first  3 4 5 6
Adam Munich
Thu Jul 15 2010, 02:22AM
^^ sounds like i'm getting a lecture on my quest for uranium/thorium metal.
Thu Jul 15 2010, 02:32AM
thats true, but previous hazards were not known (publically) like PCB's or asbestos, until the 1970's.
now at least info for toxicity is available for the public.
Thu Jul 15 2010, 08:59AM
Grenadier wrote ...
The dose rates from U exposure are orders of magnitude lower than those of the unwanted X-ray generation being discussed here.
For example, a lump of good quality pitchblende ore will come in at 70 - 100 uSv/hr with a 3cm gap between sample and detector,
(much of which activity is actually produced by Ra), while the 100kV vacuum capacitor with 10uA field emission current would produce 5 - 15 Sv/hr (assuming that lead glass is not being used) at the same distance.
Thu Jul 15 2010, 09:12AM
yes i second Proud Mary's point, U23x just isnt very emissive, cesium 137 is highly emissive in quantity and energy.
IntraWinding
Thu Jul 15 2010, 02:46PM
Grenadier wrote ...
Also, does anyone find it odd that we haven't heard from sparky again...?
Hilarious - or at least I hope so!
I think this meter can be used as two tubes at 50KV each max, or one tube at 100KV max.
You can't add metallic shielding near as it may cause arcing, or at least degrade performance due to parasitic capacitances.
Is there any way to tell if the tubes are made from lead glass?
So really you want a meter if you're playing with anything that may produce X-Ray - not only to protect yourself but out of responsibility towards neighbours! But what's the overall guidance for this meter based on all these figures?
Adam Munich
Thu Jul 15 2010, 03:06PM
There is a way to tell. Lift them up! It should be obvious if the glass is leaded.
If not, maybe he could make a lead apron. I would still go with the lead tubes though. I doubt any parasitic capacitance from lead .5" away still separated by the glass tube would be significant. Arcing can be solved with a mylar sheet.
sparky99
Thu Jul 15 2010, 04:45PM
sparky99 Registered Member #1159 Joined: Fri Dec 07 2007, 02:10AM
I'm still here and no, I haven't used the meter yet. I had the thing apart on the day I purchased it. It is divided into two separate compartments, the 2 HV vacuum caps, a bunch of 100 Meg ohm divider resistors, a dual wafer ceramic mode switch and a 6AL5 dual diode rectifier tube. The other compartment houses the power supply & drive circuits for the meter & scope output.
I'm going to pop it open again & draw a schematic of the high voltage compartment and, hopefully get a better idea if this thing will produce x-rays. Any way to tell (by looking) if the glass has Pb in it? The glass is not pink or brown, as usually found on used x-ray tubes.
bob
sparky99
Thu Jul 15 2010, 05:34PM
Here's some under the hood pictures:
1279215200 1159 FT92505 Hvmeter 001
1279215200 1159 FT92505 Hvmeter 002
1279215200 1159 FT92505 Hvmeter 004
1279215200 1159 FT92505 Hvmeter 005
sparky99
Thu Jul 15 2010, 05:35PM
And a few more:
1279215336 1159 FT92505 Hvmeter 006
1279215336 1159 FT92505 Hvmeter 007
1279215336 1159 FT92505 Hvmeter 009
sparky99
Thu Jul 15 2010, 05:41PM
In the bottom of the Vacuum cap sockets, there is a 800mmf 500 Volt doorknob cap in series with the vacuum cap. Coming up with a schematic for this is going to take a little time, the unit has 2, two wafer ceramic switches and the little wiring harness is laced.
I'm going to email Jennings and see if they can supply a manual / schematic for this unit.
Regards,
bob
first  3 4 5 6
