  • Guests: 52
ZVS flyback driver inductor help
Alex M
Sun Jun 12 2011, 06:01PM Print
Hello I am new here.
I am going to make a ZVS driver for my flyback transformer but need some help with choosing a suitable inductor.
I am using the driver seen here:
Link
Would this inductor work Link2
Please note that according to the specs it is a 2 pin 47µH inductor and not a 4 pin as shown in the picture.
Thanks!
Adam Munich
Sun Jun 12 2011, 06:15PM
I don't see any reason why it would not work. The inductor is used for filtering current spikes, so its value isn't too critical.
Ash Small
Sun Jun 12 2011, 06:16PM
Two points, firstly, it is designed as an EMI choke, so is designed to operate at 50 Hz. I think this means it is unsuitable for a Mazilli circuit, which operates at >20kHz.
Secondly, it is only rated for 10 Amps. This MAY be sufficient, but a higher current rating would probably be better.
Alex M
Sun Jun 12 2011, 06:29PM
@Grenadier Thanks.
Ash Small wrote ...
@Ash Small Where does it say that it is designed to work with mains frequency's? I had a second look on the spec page but could not find anything.
Wouldn't a higher current rating inductor work less effectively as the amount of current effects the inductance? (Sorry I do not really know that much about inductors and this is my first time making a circuit that requires one).
Thanks.
