  • Guests: 41
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
400V diodes and 320V supply in the bridge.
Dzejwor
Sun Jul 11 2010, 09:56PM Print
Dzejwor Registered Member #2750 Joined: Sun Mar 21 2010, 08:47PM
Hi. I plan to build next DRSSTC this time a small - something like microBrute. I have GA200SA60 IGBT's but they unfortunately do not have bodydiodes. I have diodes - UFB200FA40P But they are have only 400V max cathode to anode voltage. I plain to supply halfbridge with 320VDC and my question is whether that diodes are good for this job or rather I have to find something with higher max cathode to anode voltage
dmg
Sun Jul 11 2010, 10:08PM
well, if I remember correctly, you where using predikter as a driver?
I think with some TVS on the diodes just in case, you should be fine using them,
im actually on the same boat as you, as my IGBTs do not have a body diode either,
and im using these guys mounted to the bridge:
my coil runs at a lower frequency, due its size, but I dont know if these will be fast enough for a small coil.
also, your IGBTs are VERY simular to mine
Dzejwor
Sun Jul 11 2010, 11:07PM
Yes I using predikter in my previous two coils. I think my diodes are fastenough to this work. IGBTs in my two coils have 150ns diodes inside and work cool with 68kHz. I think the resonant ferq of my new coil should be at around 120kHz
