  • Guests: 48
Saving Money on Secondary Coils
quicksilver
Tue Jul 06 2010, 07:44PM Print
Does anyone know how or where to find a calculator or formula to determine the length of wire needed for the coverage of the square-inches of a secondary coil?
EXAMPLE: If one were to have a 3"diameter 24" length coil & you know that 1/4 lb of 28/coated magnet wire is 314 feet, you could save a bit of money if you knew the coverage capacity of that wire.
Let's say that 1/4 spool will cover 5 square inches; then you simply determine how much coverage that cylinder coil form has and buy only what you need, etc. {That's an example out of the blue. I don't know that will cover 5 square inches.}
It's a shame to have left over wire that would not be enough for a full coil. But to know in advance what is needed would also prevent the problem of joining a new spool 3/4 of the way to completion. Determining the area of a cylinder wouldn't be difficult but to determine the coverage level of a given wire in addition would go a long way to saving time, trouble, & money. .... Any ideas?
dmg
Wed Jul 07 2010, 12:37AM
JAVATC,
It can calculate how many feet of wire I need, wieght, etc, it seems fairly accurate so far.. in my case, I usually just use 10LB spools since ive gotten a hold of them easly, but I did once messure the wieght of the secondary before and after windings, and JAVATC was very acurate on the wire wieght, and lenth of it, turns per inch, which you can probably devide the total lenth of the secondary to figure out just how much wire is in an inch.
quicksilver
Wed Jul 07 2010, 04:47PM
Sometimes the most appropriate answers are the familiar ones! Excellent; I'll check that out.....
I once had a chance to get some large spools and I'm sorry I didn't. I'm paying serious retail at around $20-25lb. So every bit helps.
THX
dmg
Wed Jul 07 2010, 05:57PM
Yeah, Ive gotten a nice 10LB spool from a good friend of mine for fairly low price,
but if you keep an eye out, either locally or the internet, you can sometimes find really nice deals for low price 10LB spools of wire.
quicksilver
Wed Jul 07 2010, 11:26PM
I have been winding some secondaries for both future use and practice because even with a coil winder, it takes some technique to get them perfect. Particularly extreme secondary's. I cannot see how some people make those super tiny coils from 36-40 "hair-wire".....
I think that is really one of the most significant elements of any type coil and when you're winding, if you don't do it fairly often you loose your "touch". Using "hand-wound" coils always seems like a major endeavor. I came across some 1/4" copper tubing for primaries and after some slow deliberate work, I found I could wind a very clean spiral without having to place it in supports first. I picked up some "tricks" with that too. They came out very clean.
If you ever see any really cute sales please PM me. I'd really appreciate it.
Thu Jul 08 2010, 03:29PM
Just calculate circumference of your secondary, then using width of the wire you want to use (available on most wire AWG charts), determine number of turns and then finally length of the wire.
quicksilver
Thu Jul 08 2010, 05:36PM
Ouch! Thank you. You make it sound so simple I feel foolish bringing it up. I try to think of that as a formula (as it's very logical) but it's tough to get by brain around.
{Circumference=area of coil form}
{width of wire} {distance of wire}
{Number of turns}={coverage}
Thu Jul 08 2010, 06:16PM
If your secondary is 4" in diameter, then its circumference is (4*pi) = 12.56"
If you have 1200 turns, than its (1200*12.56") = 15,072" or 1256 feet.
