  • Guests: 70
OnFire (64)
01/25 Evgenij (60)
01/25 Our Finest Hour (64)
01/25 Patrick (44)
First VTTC
HazzWold 1993
Sat Jul 03 2010, 01:15AM Print
What would be a good VT for a single VT "Beginners" VTTC
Further more does anyone know of any half decent VTTC plans that use a single tube and aren't overly large? Thanks
Sat Jul 03 2010, 01:25AM
Teravolt Labs wrote ...
You should look for a triode tube, preferable with a plate dissipation around 100-300 watt, the heater atleast at some 20-30 watt and the higher voltage it can manage is good, but a few kV is best. Best get one in a glassenvelope so you can check plate heating while testing.
For the oscialltor, most uses a class c amstrong osciallator, its the one I have used in my vttc, for a single tube, just remove one of the two in my drawings f.ex. Link2
good luck with your vttc, you should also read steve wards vttc faq for some good design guidelines, Link2
HazzWold 1993
Sat Jul 03 2010, 01:55AM
Are these "brand new" chinese VT's worth trying?
StevenCaton
Sat Jul 03 2010, 05:23AM
StevenCaton Registered Member #1845 Joined: Fri Dec 05 2008, 05:38AM
Build Steve Ward's dual 811A off his site. This was my first VTTC. I built it exactly like his schematic and it worked the first time I powered it up, no problems. (well my grid feedback resistor got way too hot, but whatever)
Its a pretty easy build for a first VTTC.
(you don't have to use two 811A's though, you can just have one)
Matt Edwards
Sun Jul 11 2010, 02:10PM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
I don't know how reliable the list is but there is a list of "recommended" vacuum tube on this page. Link2
I also agree about checking out Steve Wards site also. There is some good info there.
UltraMagnus
Sun Jul 11 2010, 04:30PM
UltraMagnus Registered Member #2875 Joined: Mon May 24 2010, 08:28AM
Oidium45 wrote ...
I saw that list myself, not really very useful without more information on the individual valves. Does "recommended" mean "kinda ok" or " really very good"
quicksilver
Sun Jul 11 2010, 06:23PM
QUOTE:
"Are these "brand new" chinese VT's worth trying?"
I don't want to down Chinese goods but there are too many quality older tubes out there for you to have to settle for a "knock off". I found plenty of them when I really started to look.
UltraMagnus
Mon Jul 12 2010, 10:26AM
the are also some sellers on ebay selling old ex soviet valves, which is mostly "new old stock".
Anon01
Mon Jul 12 2010, 04:37PM
Anon01 Registered Member #1589 Joined: Sun Jul 13 2008, 06:40PM
I have an 833A I'm probably not going to use that I'm wanting to sell if you want to take that route.
Either that or check ebay and whatnot...
Mon Jul 12 2010, 10:42PM
It is funny you mention those...
I just dropped mine on the floor 2 times(once it fell and hit a hard plastic box then hit cement), and i got the heat bright red. It still works. That is a tough little thing...
They really have seemed to work well... I have had 3 in all, one broke because it rolled onto a cold steel ATX PSU lid about 2 and a half years ago, one is the one i am talking about, and one went to a friend. All that shipping and it still lights up smile
And yea, one was 14 bucks shipped, and the other two where 24 bucks shipped. Mmmm! And i have run them at 10MHz with no air cooling! Link2
