  • Guests: 61
Bauerb2 (36)
02/03 Bauerb2 (36)
02/04 Fabio (46)
02/04 Corey (35)
ZVS Parts
Antonio
Fri Jul 09 2010, 12:18AM
Those perforated boards with copper parallel lines are quite convenient for constructions, and the result is not messy.
Lines in one direction use the board, and in the other direction use jumpers. No wires under the board.
HazzWold 1993
Fri Jul 09 2010, 02:41AM
Edit : Nevermind.
quicksilver
Fri Jul 09 2010, 02:11PM
Neat and tidy little job there....Well done.
HazzWold 1993
Sat Jul 17 2010, 10:40AM
finished my driver, now need to incorporate it onto a PCB, and tidy it up.
So far total cost $21
Wed Sept 15 2010, 01:49PM
Hey,
I'm going/thinking of making a ZVS. Could you post your final parts list please?
Thanks mate smile
-Ken
(I helped you find your IRFP250s remember)
bgsniper
Wed Sept 15 2010, 07:01PM
bgsniper Registered Member #3200 Joined: Wed Sept 15 2010, 06:57PM
hi
irf530 for transistors? whats the max power of the driver with these?
my driver is built with these cheap transistors and the output arc can be seen here
The power supply is 24v. And the 10k resistors can be under 2w. My capacitor is 0.68 uF wima red color.
HazzWold 1993
Thu Sept 16 2010, 10:12AM
do you want links or Or just a parts list
Thu Sept 16 2010, 10:20AM
Both??? >.<
HazzWold 1993
Thu Sept 16 2010, 10:45AM
GhostNull wrote ...
Both??? >.<
Okay i used...
2 x IRFP250 - Link2
2 x Ultrafast diodes STTH1R04 - Link2
2 x 15v 5W Zeners 1N5352BG - Link2
1 x 680nf 850v MKP capacitor PP - Link2
And the resistors were just stated values of 470ohm and 10k, both of them were 2W and the inductor was one i pulled off an inverter microwave board. smile
Thu Sept 16 2010, 01:49PM
What I used was the aluminum tape that many use to make a TC Toroid with. I took a perfboarf (that was just a stripped Ethernet card) and cut out my little PC-board design with the tape (made it much thicker than a profession trace however) and soldered it up. It worked quite well. When I completed it and all was working - I covered it with clear lacquer. That way it was compact and the heat-sink could be attached via small screws.
I've never seen anyone succeed soldering anything to aluminum, it's inherently unsolderable. So pics or it didn't happen!
