  • Guests: 45
Can SCR's be used in parallel?
Electroholic
Thu Jul 01 2010, 08:10AM
12ms seems kinda slow, I dont think it would exceed the di/dt, problem is probably the action integral. Also, what circuit do you have? Do you have anti parallel diodes? Current and voltage limiting on the gate?
Also the S8035k has only a 500A pulse rating. which is even less than what you have right now.
If you dont want to go thru the trouble of putting SCRs in parallel, I would suggest finding a used semikron brick on ebay.
SKKT132-12E or something like that.
Z28Fistergod
Thu Jul 01 2010, 08:31AM
Z28Fistergod Registered Member #2040 Joined: Fri Mar 20 2009, 10:13PM
Unless he wasn't using any inductor in the test circuit, I'd say it's highly unlikely the di/dt was exceeded.
So, why don't we take a look at this test circuit aarp card holder? Also, tell us what makes you think the other SCRs are faulty. If we are to help you, we need more information. As for SCR alternatives, I found this one on Newark for $16.21.
50RIA120PBF 1200V 1490A surge current
There are many others to choose from. Just do a parametric search for what you want.
HV Discharge
Fri Jul 23 2010, 09:32PM
HV Discharge Registered Member #3028 Joined: Fri Jul 23 2010, 07:08PM
would rather play it safe and get a good SCR rather than "stacking" several smaller ones. especially as you will pay less for the c358n than you will for the 50RIA120 smile.
c358n are currently on ebay and are being sold in pairs, they are going for a really good price (auction). i got 4 for less than £20.
they are rated at 240A @ 800V.
ITSM, 50Hz: 3.2KA.
i used a 50RIA120 in a portable 400V, 6000uF cap bank. it died on the first shot @ only 200V. replaced it with a c358n and it handles the full 400V discharges no problem.
Jasonr
Thu Aug 19 2010, 08:05PM
Jasonr Registered Member #167 Joined: Mon Feb 13 2006, 06:41PM
18 scr's in parallel
I used this for my railgun. You have to be really careful to turn them ALL on at the same time!
Jason Rollette
