  • Guests: 61
Flipped bits
Sun Jun 27 2010, 10:52AM Print
heh.. you'd think that the new multi-GB chips would be more sensitive to this.
Interestingly it seems that ESD can cause very similar problems, for example making a chip more sensitive to temperature rises etc.
Having had at least one failed RAM chip (worked fine for months then PC kept BSOD'ing) I wonder if it was damaged when originally installed at the factory.. ?
when i get time i might try and run a read/write algorithm on a '4164 RAM chip to see how many bit flips a known radiation source causes.
-A
Sun Jun 27 2010, 11:40AM
There is an interesting report on the appearance of radiation-induced white blemishes in CCD cameras here:
TH-1087 Date: 12/21/01
and a rather good, if basic, multi-part guide here:
Radiation Hardening in Electronics
MinorityCarrier
Mon Jun 28 2010, 12:24AM
I had a Canon EOS10D SLR camera purchased in 2003 that developed lit pixels with long exposures, and I still have a Sony VX2000 DV that started displaying a single lit pixel when the camera was used on a hot day. Wonder if these are radiation-induced.
Mon Jun 28 2010, 06:35PM
MinorityCarrier wrote ...
It would seem quite possible according to TH-1087, wouldn't it, but I s'pose there's no way of establishing that any particular blemish occurred in this way, which may well be a tempting let-out for careless quality controllers.
