  • Guests: 34
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Big home made pulse caps
Pinky's Brain
Fri Jun 25 2010, 03:49PM
Polystyrene is slightly soluble in oil ...
Any way, as I said you can buy BOPP fairly cheaply (it's used to pack flowers and fruit baskets). Packaging grade BOPP should have around 200 Volt/um dielectric strength, which is so much better than anything else (except Mylar and capacitor grade film) that it doesn't really make sense to use anything else if you are going to make something big.
pauleddy
Sat Jun 26 2010, 01:16AM
pauleddy Registered Member #2909 Joined: Wed Jun 09 2010, 12:31AM
so if i made a roll with like 200m X 50cm (X2 one for each plate) of Al foil does anyone think it will run a coil gun or something like that?
Sat Jun 26 2010, 08:55AM
Only electrolytics can really get the necessary capacitance for a coil gun without being too big.
pauleddy
Sat Jun 26 2010, 02:23PM
so what if i modify an electrolytic to work at higher voltages, i recently found a pair of 100,000+ MF caps but are only rated for 15v. is their a way i could dismantal these and increase the max volts. ( something tells me this will end in some catastrophic failure)
big5824
Sat Jun 26 2010, 04:41PM
Im just going to put it simply, it isnt possible. You would get the same energy storage for 1/10th of the price just by buying some electrolytic caps, and even then a farad at lets say 500v is still larger than most universities have access to with their millions of pounds of funding.
Sat Jun 26 2010, 05:04PM
pauleddy wrote ...
Yup. for example using dielectric film like Pinky described. Though I would stay below 1000 volts for 20 um film. Link2
Suppose you had 2 foils 50 m x 0.5 m, and 2 similar areas of dielectric film -- that's 1/10 of Pinky's example, and you could get about 66 microfarads. 21 joules at 800 V - enough for a small coilgun.
I would start by making and testing a much smaller capacitor. Then if it works, make many more small ones & use them in parallel, so a single film failure doesn't destroy the whole thing.
It's a lot of work, compared to what you could do with a few free photoflash capacitors.
pauleddy
Sat Jun 26 2010, 05:37PM
yes originally i set my goals way too high with out doing much looking around and realize that it was practily impossible. so im looking to do somthing a little more on the possibity side
i have two 196,000MFD 15VDC caps the tops are broken but the foil looks intact. ( i found them from an R&D dump site they wher part of a 12v 80A PSU that where crush, but some of the caps lived) is there a way to pump higher voltages with these caps?
Pinky's Brain
Sat Jun 26 2010, 07:03PM
I don't see how really.
It's not so much impossible, it's that you want low rep-rate pulse capacitors ... and for those commercial electrolytics are unbeatable, because they are consumerized devices.
Very high voltage (>>1 kV) high rep-rate pulse caps however are boutique items, so there it makes more sense to DIY. It's just that that's not the kind of capacitor you need in a coilgun.
IntraWinding
Sun Jun 27 2010, 01:20AM
pauleddy wrote ...
To increase the voltage of your electrolytics you'd need to grow a thicker oxide layer and that would mean the capacitance would drop.
pauleddy
Sun Jun 27 2010, 11:44AM
thanks i thought as much.
