  • Guests: 51
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
TVS on external diodes for full bridge?
dmg
Wed Jun 16 2010, 05:49AM Print
Ive been putting together a bridge, however my IGBTs do not have an inbuilt diode, and in this case, I had to put external diodes, (1200V 60A diodes two per package), however I wondered if this could cause extra transients on the bridge that the TVS across my emitter and collector will have to put up with, or should I add addition TVS across the diode terminals themselves to have further protection from transients?
1276667371 2628 FT0 Igbtbridge
teravolt
Thu Jun 17 2010, 01:05AM
I would if it were my bridge but I would use 2 X 1.5ke220 instead of zeners
dmg
Thu Jun 17 2010, 01:18AM
Well, Ill try to get some TVS to replace the zeners, but wouldnt the 1.5KE220 have to high ratings to be usefull when it comes to protecting the gate?
Right now im using 33V zeners, and in the past I did not have any problems with them, but if this bridge would be used for DRSSTC, it would be my first one.
Thank you.
