  • Guests: 60
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Tesla coil PSU help
Matt Edwards
Fri Jun 11 2010, 02:54AM Print
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
I know that this is probably a stupid question but I am beginning to get frustrated. It seems that every schematic that I find for a tesla coil uses either a NST or several MOT's to power the coil... Is there another option? Could a voltage multiplier work for example?
I have a few small "vary old" flyback transformers that produce AC and several large 30KV ceramic caps. If I used them to make a small multiplier would it likely produce enough juice for a tesla coil?
I am trying to power a fairly small coil. It is approximately 10" tall using 3/4" pvc. I was origionaly using a mazilli zvs flyback driver to power it but would only get a streamer if I placed a finger near by...
Goodchild
Sat Jun 12 2010, 09:36PM
I know it is off topic but when you say Rosamond CA on your location do you mean the Rosamond right out outside of Lancaster and Palmdale?
Matt Edwards
Sun Jun 13 2010, 01:31AM
Yep
Goodchild
Sun Jun 13 2010, 04:26AM
Wow that's really cool to know that there is someone else in the area that likes HV stuff smile
Any way im assuming that your talking about SGTCs and ya you could use any method of your choosing,
as long as it has the correct power requirements of the coil you plan to build. I being a solid state kinda
guy I choose silicon to drive my coils, but as long as you are in the right voltage range and current range
any thing should work just fine.
