  • Guests: 52
GDT Core Material
Corey
Tue Jun 08 2010, 07:13AM Print
Corey Registered Member #1902 Joined: Fri Jan 02 2009, 07:59PM
I bought some cores for my class e coil awhile ago I have yet to get the drive to work right. The drive rings badly every time i draw sparks not sure why but I believe its the cores I am using at the moment the have a permabity of approx 2500. Very low from what I have read. If someone could recommend a core type for a drive of 700 khz would be awesome. Thanks
-Corey
Tue Jun 08 2010, 02:45PM
You don't need a gate drive transformer for a class-e, especially if you're frequency is only 700kHz.
Just use an IXYS IXDD414 gate driver. These are used in many class-e RF amplifiers and provide more than enough drive power for most high power MOSFETs at frequencies up to 8MHz.
We use them for our class-e designs which switch at 4MHz and drive IXFN16N50s.
Corey
Tue Jun 08 2010, 05:17PM
Well right now I'm running the gate drive with the UCC non-inverting driver connected to ground via .1uf cap and the GDT primary. I need a GDT for isolation because I'm using a 30-0-30 x-former fed through a doubler for 120VDC for the B+ and using the center tap for the low side electronics. In this situation the ground for the UCC and the Source are not at the same potential which requires me to use a GDT. So i would like to know if anyone has had success with GDT at this high of a freq and what material to use. Thanks EVR I know your trying i just have to be more clear about what I'm talking about.
-Corey
Tue Jun 08 2010, 06:57PM
Just use Fair-Rite Type 77 or Type 78 material. This is what i've used before on my class-e gate drives that used gate transformers. These were good up to 8Mhz.
Corey
Wed Jun 09 2010, 02:17AM
Cool thanks a bunch! I sure hope this fixes the ringing on my gate. Every time i draw sparks the leading edge of my drive waveform rings uncontrolably turning the fet on and off several times a cycle, even clamped with 12v zeners and a 10 ohm gate resistor! Otherwise my gate waveform looks pretty descent. As of right now I really hope it's just my GDT and not something else.
-Corey
Wed Jun 09 2010, 11:48AM
What does your circuit look like?
If you post your drive circuit, we can review it and determine if there is something else amiss.
Corey
Thu Jun 10 2010, 04:43AM
It's just like ward's class e coil only diff is i'm feeding 120vdc to the high side. And low side eg the 555 ucc are getting 30vac rectified and regulated to 12vdc. Same transformer powers both high side and low via tapped windings and doubler. Another difference is the gdt but thats pretty obvious hehe. Any other info needed?
-Corey
