  • Guests: 45
measuring high voltage.
Adam Munich
Mon Jun 07 2010, 07:40PM
Yes, but my goal is to make something cheaply using some galvanometers.
Pinky's Brain
Mon Jun 07 2010, 09:07PM
Rectify->cap->voltage divider->galvano?
Adam Munich
Mon Jun 07 2010, 09:48PM
And where will i find a 100kv+ Cap?
quicksilver
Mon Jun 07 2010, 09:50PM
This is what I've used before I found a real (RCA) surplus one in a store.
The best thing is to get a cheap DIMM and make your tests on a low current source first. Once you see what you're going to need, then you'll feel more comfortable. I would really pay attention to design. Commercial ones have a small "strike ring" in the handle & it can be an important consideration.
Some issues: if you can find quality HV resistors (high wattage ceramic) that can really help - spend your money there as most other items can be designed effectively at home.....Make the thing a bit longer than commercial ones; it's a margin of safety in unique circumstances. And remember that most things that you'll make won't take the place of a professionally manufactured one. So use caution, even if everything seems like it performs well. A cheap tester is a must. Don't run (even a good design) on your $400 Fluke.
Pinky's Brain
Mon Jun 07 2010, 11:29PM
Grenadier wrote ...
You can always make one :)
Adam Munich
Mon Jun 07 2010, 11:34PM
Pinky's Brain wrote ...
Grenadier wrote ...
chances are it will burn up on me...
Tue Jun 08 2010, 12:13AM
a 100 kv cap can be made by 2 ball bearings, under oil, canola or whatever, i use 0.5" diameter balls 1 inch apart under oil. which gives 0.7pF @150,000 volts HF, squarewave. but i use an oscope, so as not to be misconstrued as if i were a communist coward. i do not use a DMM as waveform can be as important as wave amplitude. i will post pics after i sleep.
-Patrick
Pinky's Brain
Tue Jun 08 2010, 09:18AM
With such a small capacitance you will need quite large resistors for the voltage divider to keep RC times high enough for low rep rates (and a high input impedance amplifier of course, say a TL081).
Could you make a plate capacitor out of foil-paper-plastic-paper-foil in oil and then pulled vacuum for a day? (The paper wicks, so the air should be pulled out.) Maybe fold the edges of the foil and put some extra layers of paper around the rims?
Adam Munich
Tue Jun 08 2010, 11:07AM
My vacuum pump [refrigerator compressor] burned itself up. Great suggestion though. I'll try it when i find another junker fridge. Those pumps can pull quite a strong vacuum.
Wed Jun 09 2010, 06:21AM
dont use resistors. view this page.... Link2
