  • Guests: 52
GimpyJoe (36)
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Copper and Aluminum Disks for sale.
ramses
Sat Jun 05 2010, 03:16AM Print
ramses Registered Member #1208 Joined: Thu Jan 03 2008, 05:30PM
6061-T6 Aluminum
Class II Electrical Grade Copper
72mm Diameter,
thicknesses 6,8,10,12 mm in each material.
8 disks total
The copper disks are corroded, but clean up VERY easily with mild abrasive. I would clean them before they shipped, but they would corrode by the time they got to you. the 12mm Copper disk alone is nearly 1 lb!
I will list this on ebay if anyone is interested (not on ebay yet)
IntraWinding
Sat Jun 05 2010, 06:43AM
Unusual. Where they samples?
ramses
Mon Jun 07 2010, 02:28AM
Nope. Machined from bar stock. Cut into squares, cut to octagons, then lathe turned.
I ended up using water as coolant, and letting the swarf sit on the lathe over night. Great demonstration of galvanic corrosion.
