  • Guests: 42
Sticky situation....
Nicko
Fri Jun 04 2010, 04:15AM Print
Hmmm.
Is there any way to glue/weld acrylic to PVCu?
I have PolyWeld (Dichloromethane & Methacrylate), Solvent Weld Cement (for use with uPVC, MUPVC & ABS), and some other stuff which contains pretty much the same as PolyWeld but with some acetic acid. Will any of these do the job!!
That’s it, really!
Cheers
Fri Jun 04 2010, 06:51PM
focus near UV laser on the joint between the two sheets? :)
might work.. make sure to use goggles though.
-A
