  • Guests: 54
Favourite DRSSTC calculators...
Nicko
Sun May 30 2010, 05:29AM Print
Do people have favourite (DR)SSTC calculators for MMC/Primary/Secondary configurations?
Cheers
Sun May 30 2010, 06:36AM
I have only ever used JAVATC, tried some of the others, but JAVATC is always at hand on the web no matter where I am.
Sun May 30 2010, 10:00AM
I have to agree. JAVATC is the simplest to use and works well enough.
Sun May 30 2010, 01:55PM
803 Registered Member #2807 Joined: Fri Apr 16 2010, 08:10PM
no, I think that Tesla Map is the the most simple to use. It does cost $3 though
Goodchild
Sun May 30 2010, 04:49PM
I'm going to have to say JAVATC simply the best calculator out there. Ive used it to design countless DRSSTCs
Sun May 30 2010, 05:02PM
I used to think that ScanTesla defined the pinnacle of Tesla coil computer simulation...
Cheers, Finn Hammer
Mon May 31 2010, 08:58AM
Finn, JAVATC with some added math on paper works just about as well. And it's a lot less labor intensive. That's the biggest reason why I prefer JAVATC over scantesla.
Mon May 31 2010, 07:28PM
I also say JavaTC has been the biggest help. I used to use Teslamap, but that was an older version. It was easier to use, but the calculated results did not seem to be as... in-depth.
Mon May 31 2010, 11:39PM
the new tesla map (1.13) is better. the primary number of turns needed was wrong, but is now fixed.I used javatc once but i find it hard to use. why do you need to know the hight of the room?
Tue Jun 01 2010, 12:53AM
803 wrote ...
The top of the room is also pretty much a ground plane. If you operate outside there is no need to enter anything. It helps get a more realistic secondary/toploading capacitance value.
