  • Guests: 69
First Music Tesla Coil, SSTC or DRSSTC?
Stewie
Wed May 26 2010, 07:09PM Print
Stewie Registered Member #2877 Joined: Tue May 25 2010, 03:40PM
Hello everybody!
I want to build Music tesla coil, budget 1000$, before I building flyback scheme's and SGTC. Advise any scheme,the more spark the better))) smile
In advance thanks.
coillah
Wed May 26 2010, 07:13PM
coillah Registered Member #1517 Joined: Wed Jun 04 2008, 06:55AM
SSTC's of all kinds are tricky, the DR's more so. I would suggest going ahead with a mid-sized sstc to start. The modulation is fairly straightforward as I recall...
Stewie
Wed May 26 2010, 07:43PM
Ok. I think the same way,but want beautiful sparks... smile
Thu May 27 2010, 10:37AM
Well you can choose build a SSTC have a somewhat smaller output and better sound. Or build a DRSSTC and have the sparks coming out of your switching devices. Learn from you SSTC mistakes then go for DRSSTC.
Thu May 27 2010, 11:19AM
I'd recommend an SSTC also or even a flyback modulated with a 555 timer - pretty simple stuff.
Plus, you'll probably enjoy it more than a DRSSTC using PRF modulation which in my opinion sounds like a "Kazoo on Steroids" and gets pretty old REALLY fast.
Stewie
Thu May 27 2010, 12:01PM
I'll try to make sstc Mads Barnkob Link2 and mini SSTC Steve's.
Question: Can get more sparks from Kaizer SSTC II Link2
Everyone thanks for the tips shades
Thu May 27 2010, 02:19PM
Stewie wrote ...
My SSTC II is Steve Wards SSTC5 with a fullbridge of MOSFETs, it will give you longer sparks compared to the original halfbridge as the primary coil sees a larger voltage.
