  • Guests: 35
gu5b vttc
teslaspigeon
Tue May 25 2010, 11:41AM Print
teslaspigeon Registered Member #1771 Joined: Tue Oct 21 2008, 01:23AM
hi guys
im planning to build a vttc and i have a gu5b tube
the thing is i dont have a socket for it nor do i have a schematic
i was wondering if anybody on this list has a socket for sale
and also i was wondering if anybody has a schematic they could throw my way
as a rough guide to component values and such
thanks
earl
Tue May 25 2010, 11:58AM
Here is the bi-lingual data sheet with characteristic curves for the Russian GU5B triode valve, from which the component values and cooling requirments can be readily derived:
The socket is one of those forced air types, so you'll save a lot of money, and probably do a better job, by making it yourself.
Tue May 25 2010, 03:18PM
Many VTTCs uses the same oscillator, a class C armstrong. You can see a example of my VTTC here, there is some good information and links to other VTTC related sites you should read.
teslaspigeon
Wed May 26 2010, 08:05AM
thanks guys
teslaspigeon
Thu Jun 10 2010, 01:01AM
guys
what is the max voltage the tube will take i have just upgraded to two mots in series and a doubler
vasil has also done this
but will the tube take the full 8kv from the doubler or must i stay within say 5-6kv
imgetting longer sparks but i dont want to up the power too much for fear of damaging the tube
Thu Jun 10 2010, 01:38AM
803 Registered Member #2807 Joined: Fri Apr 16 2010, 08:10PM
You never know untill you push it too far!!:-D
Some people put 4kvolts on a 811a and it's only rated to 1500 volts.
teslaspigeon
Thu Jun 10 2010, 02:46PM
according to vasil
the tube will take a full 8kv thats real good news because i wasnt happy with my current spark length only 10 inches but that was with only 1 mot ive now upgraded to 2xmot in series with a doubler and the sparks are much longer at only half way up the variac only thing is im not sure my short secondary will allow me to use fulll power , it may strike the primary or the feedback coil
im toying with the idea of putting the tickler inside the secondary has anybody tried this
Matt Edwards
Fri Jul 09 2010, 12:41AM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
How well did the duel mots work? I am working on a duel 811A and was thinking about using a 3400v transformer that I have from an old heathkit HA-10
Dr. Drone
Sat Jul 10 2010, 05:15AM
shades
