  • Guests: 53
driving CM600s
Hon1nbo
Mon May 24 2010, 09:16PM Print
ok, so I am reviving my Capacitor Bank Project to some degree. I have most major assembly done, but have two things remaining before testing: charging circuit, but this is easy to build for a basic test rig
the second thing left is a circuit to drive the CM600 switch for controlling the pulses. I am saving the triggered spark gap for future use, as it requires a higher bank voltage and to get things started I plan to test with just 500V
since the CM600s are practically the white elephant of hobby high voltage electronics, I want to make sure that any needs they have are met.
How should I go about driving these in a non-SSTC environment? I would need to be able to turn on and leave on, and eventually turn off after a delay.
For some reason I get the feeling that 12V through the gate via a second transistor will not perform well lol
-Jimmy
Hon1nbo
Wed May 26 2010, 08:25PM
I found a CM600 driver board on the eastern voltage research site, will this work for something other than a SSTC?
here
-Jimmy
ScotchTapeLord
Wed May 26 2010, 09:01PM
I would think just using a CM600 as a switch for discharging a capacitor would be easier than using it in a SSTC.
I don't see why you couldn't get away with a 555 in monostable with properly chosen timing components along with a gate driver. For just one pulse, as opposed to tens of thousands of pulses per second, I would imagine a UCC37322/27322 would work just fine, even on a CM600. If you want to go bigger or use a higher gate voltage then just use some fast BJTs or FETs in push-pull configuration.
I would think it would be easier than with a SSTC, because without all the noise, you don't have to concern yourself with putting a negative voltage on the gate, just an ON voltage and 0.
The only other thing I can think of is maybe something to monitor the current through the system... but I think you should be okay with such a hefty brick.
Hon1nbo
Thu May 27 2010, 02:20AM
ScotchTapeLord wrote ...
I'll give that a try, I thought the bricks needed something special. I've never used a brick before. I also wanted to eventually build an SSTC out of the two I have, assuming I didn't fry them. I guess I can start out with a basic driver and see how it works.
-Jimmy
Thu May 27 2010, 10:22AM
Just make sure you saturate them. But why do you want to use IGBT's and what energy / load are we talking about. I have a feeling that there are far more suitable switching devices for your application. The chances of destroying your brick are quite high whilst switching an inductive load.
Hon1nbo
Thu May 27 2010, 03:36PM
Dalus wrote ...
I have a total of 4.2 kJ at the moment, but will likely not be using that much for a single pulse. I want to use an IGBT so that I can control the pulse length, and eventually have more efficient and well timed multi-stage devices. Also, I thought about using these IGBTs in an Arc Welder Controller (one of the reasons these things are manufactured) as a type of Photographic Flash for certain purposes.
-Jimmy
Thu May 27 2010, 08:44PM
As long as you keep the device operating in spec there shouldn't be any problems. Using a UCC37321 would suffice to keep the IGBT in saturation.
