  • Guests: 42
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Ultrasonic Cleaner
radiotech
Mon May 24 2010, 11:23PM
That's all there was to the circuit description. schematic is in 2 parts-(small scanner)
1274743418 2463 FT89650 Scan0034
1274743418 2463 FT89650 Scan0035
Bjørn
Tue May 25 2010, 03:13AM
If you use software like Autostitch or Microsoft ICE you can join up any number of scans automatically.
IntraWinding
Tue May 25 2010, 06:21AM
Thanks very much for the scans, and thanks for the software advice too.
My tank seems to be working significantly better at high temperature (had to settle for 70C-75C), and maybe boiling the water helped, but the washing up liquid made no difference. Perhaps the higher temperature helped tune the resonance. I used a large sheet of foil and it showed a very uneven distribution of holes: some large areas where completely eaten away whilst other areas barely showed any effect. One transducer appears to be more effective than the other.
Testing it on some real jobs, overall I'm much happier with the tank used this way but I'm keen to investigate the circuit now I have one as an example.
I'm also going to build an acoustic foam lined box!
