  • Guests: 33
direction of sec and pri coils
1 2 3 4
Thu May 20 2010, 11:50PM Print
803 Registered Member #2807 Joined: Fri Apr 16 2010, 08:10PM
are the coils of the sec and pri and feedback in the same direction? I've seen some in the same dri and others in different dir. i allways thought it was the same direction.:-?
dmg
Fri May 21 2010, 12:02AM
I assume we are talking about tesla coils,
from all the coils I built, I never gave a second thought about the direction of the coils,
it does not really matter, to any significant extent.
ScotchTapeLord
Fri May 21 2010, 12:04AM
For some designs the coils work better in the same direction, and for some, the reverse!
;) I recommend doing what works better.
... Though, it seems no one challenged the position of the tickler coil, so it looks like your previous question got answered. :)
dmg
Fri May 21 2010, 12:05AM
huh, then diregard my last post, since in SGTC wise, I never noticed any difference, I forgot you are building a VTTC tongue
Fri May 21 2010, 12:36AM
So it's in the same direction? I'm confused!!!!!!
(the post you gave me doesn't realy give an answer, it gives it may or may not work.
and what about feed back posion?
Thanks,
Paul
radiotech
Fri May 21 2010, 05:08AM
Read the caption for this illustration:
1274418490 2463 FT89527 Scan0022
Fri May 21 2010, 11:38AM
so there are multiple posiblites, well at least I'm young.:-D
radiotech
Fri May 21 2010, 03:57PM
803 wrote
so there are infinite possiblites, well at least I'm young.:-D
And the best part is that you may be the one to discover a new and better circuit that everyone will use.
ScotchTapeLord
Fri May 21 2010, 04:03PM
This is the fundamental difference between a builder and an experimenter... the potential for discovery and/or improvement.
Fri May 21 2010, 04:06PM
best of all I'm doing something no one has done in a vttc- provide real bias to the screen in a 803, I don't want to "tie the grids together" I want to see how the voltage applied screen affects vttc ops.
