  • Guests: 55
Gate-emitter voltage question
Mrkva
Thu May 20 2010, 01:32AM Print
Mrkva Registered Member #2655 Joined: Wed Jan 27 2010, 04:09PM
Hi,
I'm a little bit curious - I was doing a little research on the (DR)SSTC field and I've figured out that most of you are driving gates of your IGBTs at 24V or even 30V. But on the other side, there's usually listed +-20V as an "Absolute maximum rating" for the Vge. So, is there any way, how can I safely measure how far can I go (cause I don't like to risk blowing gates)?
Thu May 20 2010, 09:17AM
Yes, crank up the gate voltage until the IGBT is destroyed, then back it off a little. smile
A more sensible approach is to decide how much primary current you want, and look at the IGBT datasheet to see how much gate voltage corresponds to that current. You may not even need to overvolt the gate, or you may decide to upgrade to larger IGBTs that can handle more current without needing overdriven. My Mjollnir DRSSTC runs at 15V gate drive and about 450A primary current.
However, most DRSSTC builders don't work this way, their answer to the design question "How much primary current" is just "Moar!"
Mrkva
Thu May 20 2010, 12:16PM
Steve McConner wrote ...
Well, I can't go this way - at least not now because I'm limited by the circuit breaker - average current 16A at 230V. Well, with interupter duty cycle<5%, I can still get quite huge primary current :)
Thu May 20 2010, 12:32PM
Mrkva wrote ...
Yes, that is the whole point of a DRSSTC. A typical interrupter duty cycle would be something like 1% to 2%. (roughly 100us burst length, 100Hz repetition rate)
A good medium-sized DRSSTC will have maybe 50 to 100kW output power during the burst. You can't run that off a wall outlet with more than a few percent duty.
Thu May 20 2010, 12:40PM
Earlier on during the DRSSTC boom in the first part of this century, there was a trend for over-voltaging the gates. However, in my experience, i really haven't found much benefit to it, even though i sometimes myself still do this. But for most designs, i usually run about 15V maximum (1:1 GDT) on the gates.
Goodchild
Thu May 20 2010, 03:07PM
I usually run about 24v on 30v rated gates I find this to be a good gate drive voltage.
